rebirth24 Posted December 23, 2017 Posted December 23, 2017 Did some searching and couldn't find (although I am sure it was probably covered). Is there a reason why I specify the ISY Category "Scene" as an Alexa Type "light" in the ISY portal that it still shows up as a Scene over on the alexa side? Am I doing something wrong?
bmercier Posted December 23, 2017 Posted December 23, 2017 Ask Alexa: "Alexa, refresh my devices" This will refresh the change from ISY Portal to Echo. Benoit
rebirth24 Posted December 23, 2017 Author Posted December 23, 2017 Ask Alexa: "Alexa, refresh my devices" This will refresh the change from ISY Portal to Echo. Benoit This didn't change anything. Devices are still showing up as scenes in Alexa even though it is supposed to be a light.
stusviews Posted December 23, 2017 Posted December 23, 2017 Alexa never forgets unless specifically told to. You probably have both entries. In any case, forget the errant "scene," (both if it's both a scene and a device) and re-discover. It should appear as only a device. You may have to wrestle with both the smartphone and computer app separately if you use both.
rebirth24 Posted December 23, 2017 Author Posted December 23, 2017 (edited) Alexa never forgets unless specifically told to. You probably have both entries. In any case, forget the errant "scene," (both if it's both a scene and a device) and re-discover. It should appear as only a device. You may have to wrestle with both the smartphone and computer app separately if you use both. I "forgot" living room lights and rediscovered living room lights. Even though Alexa category "Light" is selected it still pulled into Alexa as a scene. It basically appears that the "alexa" device category being specified in the portal is being completely ignored and it is just using the ISY category. Edited December 23, 2017 by rebirth24
larryllix Posted December 23, 2017 Posted December 23, 2017 I "forgot" living room lights and rediscovered living room lights. Even though Alexa category "Light" is selected it still pulled into Alexa as a scene. It basically appears that the "alexa" device category being specified in the portal is being completely ignored and it is just using the ISY category. The two category selections are not related. One is an ISY category and the other is Alexa's categorisation = "device" or "not a device". This caused me some grief, at first, wondering where half my devices went.
rebirth24 Posted December 23, 2017 Author Posted December 23, 2017 The two category selections are not related. One is an ISY category and the other is Alexa's categorisation = "device" or "not a device". This caused me some grief, at first, wondering where half my devices went. I have no idea how that relates to the issue? Are you saying that the specification of the Alexa category in the ISY portal is irrelevant? So why is it even there? I need to control these as LIGHTS in Alexa. Sent from my SM-T710 using Tapatalk
larryllix Posted December 23, 2017 Posted December 23, 2017 I have no idea how that relates to the issue? Are you saying that the specification of the Alexa category in the ISY portal is irrelevant? So why is it even there? I need to control these as LIGHTS in Alexa. Sent from my SM-T710 using Tapatalk I believe this categorisation by Alexa is or the prupose of linking only certain devices to an Amazon device. Since I do not have an android v5.0+ OS (or maybe an iOS device) this is only a PITA to me.
bmercier Posted December 26, 2017 Posted December 26, 2017 @rebirth24, In Alexa, does your ISY scene appear under devices, or under scenes? If it appears under devices, this is the expected behavior. Benoit
ScottAvery Posted December 26, 2017 Posted December 26, 2017 @rebirth24, In Alexa, does your ISY scene appear under devices, or under scenes? If it appears under devices, this is the expected behavior. Benoit I suspect the confusion for OP is that Alexa describes the device as "ISY Scene address #####" but it does appear under devices and works as expected, for me anyhow.
bmercier Posted December 26, 2017 Posted December 26, 2017 That’s also my impression Sent from my iPhone using Tapatalk
ScottAvery Posted December 26, 2017 Posted December 26, 2017 I have no idea how that relates to the issue? Are you saying that the specification of the Alexa category in the ISY portal is irrelevant? So why is it even there? I need to control these as LIGHTS in Alexa. Sent from my SM-T710 using Tapatalk This only works if you switched to the V3 skill, where type can be used by Alexa. If you have done that, then selecting category lights makes your scene appear under the device heading, which will let you use it for "light only" actions in the Amazon ecosystem.
rebirth24 Posted December 26, 2017 Author Posted December 26, 2017 This only works if you switched to the V3 skill, where type can be used by Alexa. If you have done that, then selecting category lights makes your scene appear under the device heading, which will let you use it for "light only" actions in the Amazon ecosystem. Boom! Completely my BAD on this one guys. I thought (or assumed) I was at V3 and of course I wasn't...ugh... Sorry for the bother/confusion.
asbril Posted December 27, 2017 Posted December 27, 2017 Ask Alexa: "Alexa, refresh my devices" This will refresh the change from ISY Portal to Echo. Benoit For Google Home, OK Google Update my Devices or Synch my Devices.... 2
bmercier Posted December 27, 2017 Posted December 27, 2017 For Google Home, OK Google Update my Devices or Synch my Devices.... Good to know, I was not aware of this one. Benoit 2
