Not able to use admin console on Surface.
I guess my problem is that I don't have Java installed on my Surface Book but I don't use Java for anything and I don't miss the aggravations of having Java on a computer.
Is there any other way or console application that doesn't use Java?
Unfortunately, java is required to run the adminc. I use it on my surface. The other option is to "remote in" (Remote Desktop, etc) to a computer on your network that has java and the adminconsole
Paul
You might have to upgrade your Surface Book OS to get java installed. I believe the book comes with Windows 10 S, you need Pro. It's a free upgrade right now.
Thanks. If anything has changed with java I'd consider adding it but on my last HP laptop it always gave me messages about updating, I hated it. Also, I've had this Surface Book for two years and I have no third party protection and I've not had any issues. This is a work computer so it's nice that It's stable but my old HP had to be cleaned and I ran third party protections to try to keep it okay. I may be way off base and I welcome you to tell me I am and that java is safe to have on a laptop.
I believe java is safe for me in that the only java app i use is the admin console, and I only run that locally locally from the shortcut into java cache, based on a download from UDI.
I set java so it can't do anything else:
  • Under the java control panel, security, I unchecked the first box for allowing java to run from a webstart. Not that it matters much anymore, most browsers won't run java applets.
  • To make it annoyance free, I unchecked the box to check for updates under update. I typically update java when I update the admin console. I would update it if there was a news story about a significant threat that would affect me.
I used to run the admin console on my work computer, however after a security update a few years back, it quit running. My ms surface is my personal tablet and I can run the AC remotely if needed.
Paul
