io_guy Posted January 7, 2018 Posted January 7, 2018 So I got really fed up with the communication module in my Brultech GEM. It's crap. It's a cheap USR-WIFI232-B serial to net converter that half-worked at best: Will likely never see a KRACK patch Setup was absolutely non-intuitive Security hole where the AP Wi-Fi could leak through Ethernet. Had to set my switch to force 100Mbit cause it broke @ 1000Mbit 3 of 4 times I'd request a webpage it failed Constant issues with corrupt data being received So, I added serial port support to NodeLink's GEM module and connect a USB-Serial adapter from my Pi to the COM port on the GEM. I even physically removed the GEM Wi-Fi chip - good riddance. Been running for about 12h, zero issues with corrupt data and the GEM web config is way smoother. Since I'm back to a RPi (instead of Synology Docker) I'm also going to move the 1-wire back to a hardware chip and OWFS instead of the GEM bit-banging. Win-Win.
Toddimus Posted January 7, 2018 Posted January 7, 2018 io_guy, Can I ask why you ditched the Synology Docker and went back to RPi? Was it just to be able to use the USB-Serial adapter more easily? I actually just did the opposite with my NodeLink setup (i.e. from RPi to Synology Docker).
io_guy Posted January 7, 2018 Author Posted January 7, 2018 Yep, cause my Pi is 5' from the GEM and Synology is 50' across a drywalled basement. Also, the majority of people use a Pi so it helps me debug issues. The Synology is a way better way to go (vs. the Pi), the location just didn't work. I run a dozen dockers, it's fantastic (and so much faster).
Toddimus Posted January 7, 2018 Posted January 7, 2018 Whew! You had me worried that I was going in the wrong direction. Sent from my iPhone using Tapatalk
