Can you use your browser (REST) to query the COMMAND_CLASS_VERSION VERSION_GET?
I know that you can use your browser (REST) to access your ISY994 Z-Wave devices ...
http://<your-isy-ip>:<port>/rest/zwave/node/ZW034_1/info/get
This allows you to see the current status of the device.  This was an Aeotec Multisensor 6:
<nodeinfo>
<node id="ZW034_1" type="118">
<sts>
<st id="UV" uom="71"/>
<st id="CLIHUM" uom="22"/>
<st id="LUMIN" uom="36"/>
<st id="CLITEMP" uom="4"/>
<st id="BATLVL" uom="51"/>
<st id="ST" uom="51"/>
</sts>
<ctls>
<ctl id="DON" uom="51"/>
</ctls>
</node>
</nodeinfo>
And I see that you can query and change parameters of the device, too.
/rest/zwave/node/<nodeAddress>/config/query/<parameterNumber>
/rest/zwave/node/<nodeAddress>/config/set/<parameterNumber>/<value>/<size>
My question is whether or not there is a way to issue other commands to the device ... for example, COMMAND_CLASS_VERSIONVERSION_GET?
Can someone point me in the right direction?
