Thermostat setpoint should be "heat setpoint" or..
When I go to the admin console, on the "main" tab, I click on the thermostat on the left and the readout to the right has "current state" "setpoint" and "humidity".
The readout for "setpoint" reads the last change that was made to the setpoint, but if the last setpoint change that was made was to the "cool setpoint", it will show that number, even if the thermostat is in "heat" mode.
Would it be possible to have four readings ("current state", "heat setpoint", "cool setpoint", "humidity")? or does the insteon adapter for the thermostat not support this.
