KeypadLinc button flash when non toggle
Hi,
Is there a way to stop a KeypadLinc from flashing its button when in Non-Toggle mode?
I've noticed that when set to Toggle, the respective button goes on or off when pressued
When set to Non-Toggle (on or off) the button flashes 3 times before staying lit or going off. I'd like to disable this "feature"
Thanks for any input,
Ben
Hi,
Ben
I'm not aware of an option to disable the "flash". I believe it's an indicator that the button action was processed.
Thanks. I figured out how to turn this feature off for anyone interested. I had several non-toggle keypadlinc buttons that did not flash so I was racking my brain to figure out what the difference was between them and this particular device.
In the end, I figured out that if the non-toggle keypadlinc button controls any other responder (button) on the same keypadlinc then it does not flash. If it has no responders, or controls responders other than on the same keypadlinc then it flashes.
Hope this is helpful to someone.
Ben
