jca001 Posted March 4, 2018 Share Posted March 4, 2018 Everything seems to be working fine today. I still suggest the Temp and Humidity should be NN.F as they appear in the Wireless Tag Manager. I cannot see somebody want to know if either has changed by hundreds. If I remember correctly you stated on GitHub that type 62 is not supported because you thought nobody used it. The Wireless Tag Manager allows you to include Honeywell Wifi Thermostats, which I did. So it is showing up as tag type 62 below. So it would be nice to have it supported in WirelessTag. I don't really want to control the thermostats, just be able to see the values to decide to turn on/off overhead fans in various rooms. And as somebody else wanted to be able to compare humidity in one location as compared to the bathroom to decide to turn on exhaust fan. Node Name 14 Address NodeDef ID Enabled Primary Node Is Primary Delete MAIN FLOOR@Fallowfield Lane 0c4ee181bad016 wTag62F true a9864cc75ff4 false Driver UOM Value ST 2 1 GPV 56 -1 UOM 56 1 GV1 56 62 CLITEMP 17 75 BATLVL 51 94 CV 72 3 GV7 25 0 GV9 25 0 GV13 25 0 GV14 25 0 ALARM 25 5 CLIHUM 22 33 GV10 25 0 Link to comment Share on other sites More sharing options...
Chioti Posted March 4, 2018 Share Posted March 4, 2018 I'm stuck on step 4 of the installation as I never see the message. In the log I get the following errors: 2018-03-04 14:37:13,360 INFO Polyglot v2 Interface Starting... 2018-03-04 14:37:13,650 INFO Received Config from STDIN. 2018-03-04 14:37:13,813 INFO Connecting to MQTT... localhost:1883 2018-03-04 14:37:13,830 INFO wtController:init: Initializing VERSION=0.0.16 2018-03-04 14:37:13,831 ERROR c=<wt_nodes.wtController.wtController object at 0x106397160> 2018-03-04 14:37:13,834 INFO MQTT Connected with result code 0 (Success) 2018-03-04 14:37:13,834 INFO MQTT Subscribing to topic: udi/polyglot/ns/2 - MID: 1 Result: 0 2018-03-04 14:37:13,834 INFO MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2018-03-04 14:37:13,834 INFO Sent Connected message to Polyglot 2018-03-04 14:37:13,858 INFO Adding node WirelessTagsController(wtcontroller) 2018-03-04 14:37:13,858 INFO Waiting on Controller node to be added....... 2018-03-04 14:37:13,858 INFO Updating Driver wtcontroller - ST: 1 2018-03-04 14:37:13,858 INFO wtController:start: WirelessSensorTags Polyglot... 2018-03-04 14:37:13,859 ERROR wtController:load_params: oauth2_code not defined in customParams, please authorize 2018-03-04 14:37:13,859 INFO Updating Driver wtcontroller - GV3: 0 2018-03-04 14:37:13,859 INFO Updating Driver wtcontroller - GV4: 0 2018-03-04 14:37:13,863 ERROR Exception in thread Thread-1: Traceback (most recent call last): File "/Users/mac/.polyglot/nodeservers/WirelessTag/wtServer.py", line 100, in get_network_ip s.connect((rhost, 0)) OSError: [Errno 49] Can't assign requested address During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/Cellar/python3/3.6.3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/threading.py", line 916, in _bootstrap_inner self.run() File "/usr/local/Cellar/python3/3.6.3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/threading.py", line 864, in run self._target(*self._args, **self._kwargs) File "/Users/mac/Library/Python/3.6/lib/python/site-packages/paho/mqtt/client.py", line 2650, in _thread_main self.loop_forever(retry_first_connection=True) File "/Users/mac/Library/Python/3.6/lib/python/site-packages/paho/mqtt/client.py", line 1481, in loop_forever rc = self.loop(timeout, max_packets) File "/Users/mac/Library/Python/3.6/lib/python/site-packages/paho/mqtt/client.py", line 1003, in loop rc = self.loop_read(max_packets) File "/Users/mac/Library/Python/3.6/lib/python/site-packages/paho/mqtt/client.py", line 1284, in loop_read rc = self._packet_read() File "/Users/mac/Library/Python/3.6/lib/python/site-packages/paho/mqtt/client.py", line 1849, in _packet_read rc = self._packet_handle() File "/Users/mac/Library/Python/3.6/lib/python/site-packages/paho/mqtt/client.py", line 2305, in _packet_handle return self._handle_publish() File "/Users/mac/Library/Python/3.6/lib/python/site-packages/paho/mqtt/client.py", line 2500, in _handle_publish self._handle_on_message(message) File "/Users/mac/Library/Python/3.6/lib/python/site-packages/paho/mqtt/client.py", line 2647, in _handle_on_message self.on_message(self, self._userdata, message) File "/Users/mac/Library/Python/3.6/lib/python/site-packages/polyinterface/polyinterface.py", line 221, in _message self.inConfig(parsed_msg[key]) File "/Users/mac/Library/Python/3.6/lib/python/site-packages/polyinterface/polyinterface.py", line 431, in inConfig watcher(config) File "/Users/mac/Library/Python/3.6/lib/python/site-packages/polyinterface/polyinterface.py", line 588, in _gotConfig self.start() File "/Users/mac/.polyglot/nodeservers/WirelessTag/wt_nodes/wtController.py", line 73, in start self.wtServer.start() File "/Users/mac/.polyglot/nodeservers/WirelessTag/wtServer.py", line 121, in start self.rest.start() File "/Users/mac/.polyglot/nodeservers/WirelessTag/wtServer.py", line 68, in start self.myip = self.get_network_ip('8.8.8.8') File "/Users/mac/.polyglot/nodeservers/WirelessTag/wtServer.py", line 102, in get_network_ip self.l_error("get_network_ip","Failed to open socket to " + rhost) AttributeError: 'wtREST' object has no attribute 'l_error' 2018-03-04 14:37:13,865 WARNING /usr/local/Cellar/python3/3.6.3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/threading.py:949: ResourceWarning: unclosed <socket.socket fd=9, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted March 4, 2018 Author Share Posted March 4, 2018 5 hours ago, jca001 said: Everything seems to be working fine today. I still suggest the Temp and Humidity should be NN.F as they appear in the Wireless Tag Manager. I cannot see somebody want to know if either has changed by hundreds. If I remember correctly you stated on GitHub that type 62 is not supported because you thought nobody used it. The Wireless Tag Manager allows you to include Honeywell Wifi Thermostats, which I did. So it is showing up as tag type 62 below. So it would be nice to have it supported in WirelessTag. I don't really want to control the thermostats, just be able to see the values to decide to turn on/off overhead fans in various rooms. And as somebody else wanted to be able to compare humidity in one location as compared to the bathroom to decide to turn on exhaust fan. Node Name 14 Address NodeDef ID Enabled Primary Node Is Primary Delete MAIN FLOOR@Fallowfield Lane 0c4ee181bad016 wTag62F true a9864cc75ff4 false Driver UOM Value ST 2 1 GPV 56 -1 UOM 56 1 GV1 56 62 CLITEMP 17 75 BATLVL 51 94 CV 72 3 GV7 25 0 GV9 25 0 GV13 25 0 GV14 25 0 ALARM 25 5 CLIHUM 22 33 GV10 25 0 Yes, I'm fine with changing to one decimal precision. Yes, if 62 is how a Honeywell thermostat shows up then I'm all for it. I actually have a Honeywell TCC at my lake house where my second tag manager is going. Can you search in your log for 'Got Tag' and show me that line. Edit: added https://github.com/jimboca/udi-wirelesstag-poly/issues/14 Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted March 4, 2018 Author Share Posted March 4, 2018 27 minutes ago, Chioti said: I'm stuck on step 4 of the installation as I never see the message. In the log I get the following errors: File "/Users/mac/.polyglot/nodeservers/WirelessTag/wtServer.py", line 68, in start self.myip = self.get_network_ip('8.8.8.8') File "/Users/mac/.polyglot/nodeservers/WirelessTag/wtServer.py", line 102, in get_network_ip self.l_error("get_network_ip","Failed to open socket to " + rhost) AttributeError: 'wtREST' object has no attribute 'l_error' 2018-03-04 14:37:13,865 WARNING /usr/local/Cellar/python3/3.6.3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/threading.py:949: ResourceWarning: unclosed <socket.socket fd=9, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> I fixed the error in my code and will release later. But, the real error is that it is unable to connect ping the google dns server 8.8.8.8, this is a stupid trick I have to use to get the IP address of the current machine. The code works on a RPi, but not on your computer? I might be able to get around this, I"ll have to look into it. Link to comment Share on other sites More sharing options...
Chioti Posted March 4, 2018 Share Posted March 4, 2018 Jimbo, Maybe this will help, found this on Stack Overflow: import socket def get_ip(): s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) try: # doesn't even have to be reachable s.connect(('10.255.255.255', 1)) IP = s.getsockname()[0] except: IP = '127.0.0.1' finally: s.close() return IP Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted March 4, 2018 Author Share Posted March 4, 2018 34 minutes ago, Chioti said: Jimbo, Maybe this will help, found this on Stack Overflow: import socket def get_ip(): s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) try: # doesn't even have to be reachable s.connect(('10.255.255.255', 1)) IP = s.getsockname()[0] except: IP = '127.0.0.1' finally: s.close() return IP Yes, that works except if it hits the exception and returns the localhost address 127.0.0.1 then the TagManager will not be able to talk to Polyglot. Link to comment Share on other sites More sharing options...
Dr. Q Posted March 4, 2018 Share Posted March 4, 2018 I just added a Reed KumoSensor successfully except that the Event State never changes in the Admin. The wt log shows both open and closed coming through on that end, and the update clock resets on each Event, just not getting to the AC. Let me know if you want to see a log. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted March 5, 2018 Author Share Posted March 5, 2018 31 minutes ago, Dr. Q said: I just added a Reed KumoSensor successfully except that the Event State never changes in the Admin. The wt log shows both open and closed coming through on that end, and the update clock resets on each Event, just not getting to the AC. Let me know if you want to see a log. Yes, that's likely not working properly since I don't have one to test. Please send me the log of opening and closing. Also, the Moisture Status is showing as NA, so I guess that should be removed from the display https://github.com/jimboca/udi-wirelesstag-poly/issues/15 Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted March 5, 2018 Author Share Posted March 5, 2018 All Users, Please upgrade, restart and discover: Version 0.0.17 released see Release Notes and Upgrading. It should be available soon, but if your are impatient, I added instructions for manually updating. Link to comment Share on other sites More sharing options...
rccoleman Posted March 5, 2018 Share Posted March 5, 2018 Updated manually (git pull) and now I get this: 2018-03-04 16:55:33,873 INFO Polyglot v2 Interface Starting... 2018-03-04 16:55:33,876 INFO Received Config from STDIN. 2018-03-04 16:55:34,356 ERROR Traceback (most recent call last): 2018-03-04 16:55:34,359 ERROR File "./wirelesstags-poly.py", line 8, in <module> 2018-03-04 16:55:34,360 ERROR from wt_nodes import wtController 2018-03-04 16:55:34,361 ERROR File "/home/rcoleman/.polyglot/nodeservers/WirelessTag/wt_nodes/__init__.py", line 8, in <module> 2018-03-04 16:55:34,362 ERROR from .wtController import wtController 2018-03-04 16:55:34,363 ERROR File "/home/rcoleman/.polyglot/nodeservers/WirelessTag/wt_nodes/wtController.py", line 8, in <module> 2018-03-04 16:55:34,364 ERROR from wtServer import wtServer 2018-03-04 16:55:34,365 ERROR File "/home/rcoleman/.polyglot/nodeservers/WirelessTag/wtServer.py", line 11, in <module> 2018-03-04 16:55:34,366 ERROR import netifaces as ni 2018-03-04 16:55:34,366 ERROR ImportError 2018-03-04 16:55:34,367 ERROR : 2018-03-04 16:55:34,367 ERROR No module named 'netifaces' Link to comment Share on other sites More sharing options...
jca001 Posted March 5, 2018 Share Posted March 5, 2018 Here is the Got Tag information for both of my Honeywell thermostats. tag_type62.txt Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted March 5, 2018 Author Share Posted March 5, 2018 8 minutes ago, rccoleman said: Updated manually (git pull) and now I get this: 2018-03-04 16:55:33,873 INFO Polyglot v2 Interface Starting... 2018-03-04 16:55:33,876 INFO Received Config from STDIN. 2018-03-04 16:55:34,356 ERROR Traceback (most recent call last): 2018-03-04 16:55:34,359 ERROR File "./wirelesstags-poly.py", line 8, in <module> 2018-03-04 16:55:34,360 ERROR from wt_nodes import wtController 2018-03-04 16:55:34,361 ERROR File "/home/rcoleman/.polyglot/nodeservers/WirelessTag/wt_nodes/__init__.py", line 8, in <module> 2018-03-04 16:55:34,362 ERROR from .wtController import wtController 2018-03-04 16:55:34,363 ERROR File "/home/rcoleman/.polyglot/nodeservers/WirelessTag/wt_nodes/wtController.py", line 8, in <module> 2018-03-04 16:55:34,364 ERROR from wtServer import wtServer 2018-03-04 16:55:34,365 ERROR File "/home/rcoleman/.polyglot/nodeservers/WirelessTag/wtServer.py", line 11, in <module> 2018-03-04 16:55:34,366 ERROR import netifaces as ni 2018-03-04 16:55:34,366 ERROR ImportError 2018-03-04 16:55:34,367 ERROR : 2018-03-04 16:55:34,367 ERROR No module named 'netifaces' Sorry, missed one instruction: Run ./install.sh Link to comment Share on other sites More sharing options...
rccoleman Posted March 5, 2018 Share Posted March 5, 2018 Better? 2018-03-04 17:10:25,064 INFO wtController:get_node: adress=b16419acd1ad 2018-03-04 17:10:25,065 INFO wtController:discover: Running discover on <wt_nodes.wTagManager.wTagManager object at 0x7613ba30> 2018-03-04 17:10:25,074 ERROR Exception in thread Thread-5: Traceback (most recent call last): File "/usr/lib/python3.5/threading.py", line 914, in _bootstrap_inner self.run() File "/usr/lib/python3.5/threading.py", line 862, in run self._target(*self._args, **self._kwargs) File "/home/rcoleman/.polyglot/nodeservers/WirelessTag/wt_nodes/wtController.py", line 215, in _discover node.discover(thread=False) File "/home/rcoleman/.polyglot/nodeservers/WirelessTag/wt_nodes/wTagManager.py", line 150, in discover self._discover() File "/home/rcoleman/.polyglot/nodeservers/WirelessTag/wt_nodes/wTagManager.py", line 153, in _discover self.l_debug('discover','use_tags={}'.format(self.use_tags)) AttributeError: 'wTagManager' object has no attribute 'use_tags' 2018-03-04 17:10:51,157 DEBUG wtController:shortPoll: discover thread is done... 2018-03-04 17:10:51,158 INFO Updating Driver e04a8e9a15f78b - GV14: 27 Nevermind. Restarted the node server again and it's working now. Link to comment Share on other sites More sharing options...
Dr. Q Posted March 5, 2018 Share Posted March 5, 2018 1 hour ago, Jimbo said: Yes, that's likely not working properly since I don't have one to test. Please send me the log of opening and closing. Quote 2018-03-04 20:08:22,348 DEBUG get_handler: command=/door_opened 2018-03-04 20:08:22,348 DEBUG wtController:get_handler: processing command=/door_opened params={'zaxis': '0', 'ts': '2018-03-04T20:08:22 00:00', 'yaxis': '0', 'tmgr_mac': '8193BBA19F9B', 'orien': '0', 'xaxis': '0', 'tagid': '3'} 2018-03-04 20:08:22,349 DEBUG wTag52F:cf3203aa63bc2a:Patio Door:set_time: 1520212102,False 2018-03-04 20:08:22,350 INFO Updating Driver cf3203aa63bc2a - GV13: 1520212102 2018-03-04 20:08:22,351 INFO Updating Driver cf3203aa63bc2a - GV14: 0 2018-03-04 20:08:22,352 DEBUG get_handler: code=200 message=Command /door_opened success 2018-03-04 20:08:22,353 INFO wtHandler:log_message"GET /door_opened?tmgr_mac=8193BBA19F9B&tagid=3&orien=0&xaxis=0&yaxis=0&zaxis=0&ts=2018-03-04T20:08:22+00:00 HTTP/1.1" 200 - 2018-03-04 20:08:24,458 DEBUG get_handler: command=/door_closed 2018-03-04 20:08:24,459 DEBUG wtController:get_handler: processing command=/door_closed params={'zaxis': '0', 'ts': '2018-03-04T20:08:24 00:00', 'yaxis': '0', 'tmgr_mac': '8193BBA19F9B', 'orien': '0', 'xaxis': '0', 'tagid': '3'} 2018-03-04 20:08:24,461 DEBUG wTag52F:cf3203aa63bc2a:Patio Door:set_time: 1520212104,False 2018-03-04 20:08:24,462 INFO Updating Driver cf3203aa63bc2a - GV13: 1520212104 2018-03-04 20:08:24,464 DEBUG get_handler: code=200 message=Command /door_closed success 2018-03-04 20:08:24,465 INFO wtHandler:log_message"GET /door_closed?tmgr_mac=8193BBA19F9B&tagid=3&orien=0&xaxis=0&yaxis=0&zaxis=0&ts=2018-03-04T20:08:24+00:00 HTTP/1.1" 200 - Also, is it possible to show signal strength per tag instead of Out Of Range binary? Thanks, Chuck Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted March 5, 2018 Author Share Posted March 5, 2018 11 minutes ago, Dr. Q said: Also, is it possible to show signal strength per tag instead of Out Of Range binary? Thanks, Chuck Thanks for the log, added to https://github.com/jimboca/udi-wirelesstag-poly/issues/15 Will take a look. Will add signal strength as well: https://github.com/jimboca/udi-wirelesstag-poly/issues/16 Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted March 5, 2018 Author Share Posted March 5, 2018 16 minutes ago, rccoleman said: Better? 2018-03-04 17:10:25,064 INFO wtController:get_node: adress=b16419acd1ad 2018-03-04 17:10:25,065 INFO wtController:discover: Running discover on <wt_nodes.wTagManager.wTagManager object at 0x7613ba30> 2018-03-04 17:10:25,074 ERROR Exception in thread Thread-5: Traceback (most recent call last): File "/usr/lib/python3.5/threading.py", line 914, in _bootstrap_inner self.run() File "/usr/lib/python3.5/threading.py", line 862, in run self._target(*self._args, **self._kwargs) File "/home/rcoleman/.polyglot/nodeservers/WirelessTag/wt_nodes/wtController.py", line 215, in _discover node.discover(thread=False) File "/home/rcoleman/.polyglot/nodeservers/WirelessTag/wt_nodes/wTagManager.py", line 150, in discover self._discover() File "/home/rcoleman/.polyglot/nodeservers/WirelessTag/wt_nodes/wTagManager.py", line 153, in _discover self.l_debug('discover','use_tags={}'.format(self.use_tags)) AttributeError: 'wTagManager' object has no attribute 'use_tags' 2018-03-04 17:10:51,157 DEBUG wtController:shortPoll: discover thread is done... 2018-03-04 17:10:51,158 INFO Updating Driver e04a8e9a15f78b - GV14: 27 This should not be possible. I've attempted to recreate that and it works fine for me. Was this just a discover on the controller right after a restart? It may be possible that the restart had not completely finished when you ran discover. I tried to test that a few times and it didn't happen, likely a race condition, so I'll have to add a check for that... If you PM me the full log file, I can look deeper. In the meantime, if you run restart, wait until you see a line ending in: :shortPoll: set_url thread is done... Which should show up on the first shortPoll interval, but sometimes takes longer if the wireless tags server is slow. Link to comment Share on other sites More sharing options...
rccoleman Posted March 5, 2018 Share Posted March 5, 2018 2 minutes ago, Jimbo said: This should not be possible. I've attempted to recreate that and it works fine for me. Was this just a discover on the controller right after a restart? It may be possible that the restart had not completely finished when you ran discover. I tried to test that a few times and it didn't happen, likely a race condition, so I'll have to add a check for that... If you PM me the full log file, I can look deeper. In the meantime, if you run restart, wait until you see a line ending in: :shortPoll: set_url thread is done... Which should show up on the first shortPoll interval, but sometimes takes longer if the wireless tags server is slow. It's mysteriously working again after I restarted the node server. Yes, it was he first discover after a restart. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted March 5, 2018 Author Share Posted March 5, 2018 8 minutes ago, rccoleman said: It's mysteriously working again after I restarted the node server. Yes, it was he first discover after a restart. Thanks, yes, it's likely an issue with discover run while startup was still going. https://github.com/jimboca/udi-wirelesstag-poly/issues/17 Everyone else, if I haven't recorded your issue here https://github.com/jimboca/udi-wirelesstag-poly/issues then I missed it, so please let me know again. Get's hard to track issues or when the thread busy. Link to comment Share on other sites More sharing options...
Chioti Posted March 5, 2018 Share Posted March 5, 2018 Installed 17 but I still don't get the "message" so I can get the auth code needed...although there are fewer errors this time. 2018-03-04 21:14:05,803 INFO Polyglot v2 Interface Starting... 2018-03-04 21:14:06,093 INFO Received Config from STDIN. 2018-03-04 21:14:06,258 INFO Connecting to MQTT... localhost:1883 2018-03-04 21:14:06,275 INFO wtController:init: Initializing VERSION=0.0.17 2018-03-04 21:14:06,276 ERROR c=<wt_nodes.wtController.wtController object at 0x10fac5128> 2018-03-04 21:14:06,278 INFO MQTT Connected with result code 0 (Success) 2018-03-04 21:14:06,279 INFO MQTT Subscribing to topic: udi/polyglot/ns/2 - MID: 1 Result: 0 2018-03-04 21:14:06,279 INFO MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2018-03-04 21:14:06,279 INFO Sent Connected message to Polyglot 2018-03-04 21:14:06,305 INFO Updating Driver wtcontroller - ST: 1 2018-03-04 21:14:06,305 INFO wtController:start: WirelessSensorTags Polyglot... 2018-03-04 21:14:06,305 ERROR wtController:load_params: oauth2_code not defined in customParams, please authorize 2018-03-04 21:14:06,305 INFO Updating Driver wtcontroller - GV3: 0 2018-03-04 21:14:06,306 INFO Updating Driver wtcontroller - GV4: 0 2018-03-04 21:14:06,306 ERROR KeyError in gotConfig: 2 Traceback (most recent call last): File "/Users/mac/Library/Python/3.6/lib/python/site-packages/polyinterface/polyinterface.py", line 431, in inConfig watcher(config) File "/Users/mac/Library/Python/3.6/lib/python/site-packages/polyinterface/polyinterface.py", line 588, in _gotConfig self.start() File "/Users/mac/.polyglot/nodeservers/WirelessTag/wt_nodes/wtController.py", line 73, in start self.wtServer.start() File "/Users/mac/.polyglot/nodeservers/WirelessTag/wtServer.py", line 136, in start self.st = self.rest.start() File "/Users/mac/.polyglot/nodeservers/WirelessTag/wtServer.py", line 69, in start self.myip = self.get_network_ip() File "/Users/mac/.polyglot/nodeservers/WirelessTag/wtServer.py", line 118, in get_network_ip ifaddr = ni.ifaddresses(iface)[ni.AF_INET][0] KeyError: 2 Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted March 5, 2018 Author Share Posted March 5, 2018 Installed 17 but I still don't get the "message" so I can get the auth code needed...although there are fewer errors this time. 2018-03-04 21:14:05,803 INFO Polyglot v2 Interface Starting... 2018-03-04 21:14:06,093 INFO Received Config from STDIN. 2018-03-04 21:14:06,258 INFO Connecting to MQTT... localhost:1883 2018-03-04 21:14:06,275 INFO wtController:init: Initializing VERSION=0.0.17 2018-03-04 21:14:06,276 ERROR c= 2018-03-04 21:14:06,278 INFO MQTT Connected with result code 0 (Success) 2018-03-04 21:14:06,279 INFO MQTT Subscribing to topic: udi/polyglot/ns/2 - MID: 1 Result: 0 2018-03-04 21:14:06,279 INFO MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2018-03-04 21:14:06,279 INFO Sent Connected message to Polyglot 2018-03-04 21:14:06,305 INFO Updating Driver wtcontroller - ST: 1 2018-03-04 21:14:06,305 INFO wtController:start: WirelessSensorTags Polyglot... 2018-03-04 21:14:06,305 ERROR wtController:load_params: oauth2_code not defined in customParams, please authorize 2018-03-04 21:14:06,305 INFO Updating Driver wtcontroller - GV3: 0 2018-03-04 21:14:06,306 INFO Updating Driver wtcontroller - GV4: 0 2018-03-04 21:14:06,306 ERROR KeyError in gotConfig: 2 Traceback (most recent call last): File "/Users/mac/Library/Python/3.6/lib/python/site-packages/polyinterface/polyinterface.py", line 431, in inConfig watcher(config) File "/Users/mac/Library/Python/3.6/lib/python/site-packages/polyinterface/polyinterface.py", line 588, in _gotConfig self.start() File "/Users/mac/.polyglot/nodeservers/WirelessTag/wt_nodes/wtController.py", line 73, in start self.wtServer.start() File "/Users/mac/.polyglot/nodeservers/WirelessTag/wtServer.py", line 136, in start self.st = self.rest.start() File "/Users/mac/.polyglot/nodeservers/WirelessTag/wtServer.py", line 69, in start self.myip = self.get_network_ip() File "/Users/mac/.polyglot/nodeservers/WirelessTag/wtServer.py", line 118, in get_network_ip ifaddr = ni.ifaddresses(iface)[ni.AF_INET][0] KeyError: 2 Yes, there is more error trapping, but the new code still can't figure out your IP address. What are you running this on?Sent from my Pixel 2 XL using Tapatalk Link to comment Share on other sites More sharing options...
Chioti Posted March 5, 2018 Share Posted March 5, 2018 MacOS High Sierra Link to comment Share on other sites More sharing options...
Scottmichaelj Posted March 5, 2018 Share Posted March 5, 2018 Everything seems to be working fine today. I still suggest the Temp and Humidity should be NN.F as they appear in the Wireless Tag Manager. I cannot see somebody want to know if either has changed by hundreds. If I remember correctly you stated on GitHub that type 62 is not supported because you thought nobody used it. The Wireless Tag Manager allows you to include Honeywell Wifi Thermostats, which I did. So it is showing up as tag type 62 below. So it would be nice to have it supported in WirelessTag. I don't really want to control the thermostats, just be able to see the values to decide to turn on/off overhead fans in various rooms. And as somebody else wanted to be able to compare humidity in one location as compared to the bathroom to decide to turn on exhaust fan. Node Name 14 Address NodeDef ID Enabled Primary Node Is Primary Delete MAIN FLOOR@Fallowfield Lane 0c4ee181bad016 wTag62F true a9864cc75ff4 false Driver UOM Value ST 2 1 GPV 56 -1 UOM 56 1 GV1 56 62 CLITEMP 17 75 BATLVL 51 94 CV 72 3 GV7 25 0 GV9 25 0 GV13 25 0 GV14 25 0 ALARM 25 5 CLIHUM 22 33 GV10 25 0 Interesting I can seem to get my Honeywell TCC stats to work. Keep getting “authorization error” - they once worked but stopped. I thought this was a wireless tag issue. They show up with info when they are added however “update” gives me the error. Can you confirm yours are ok? Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted March 5, 2018 Author Share Posted March 5, 2018 1 hour ago, Chioti said: MacOS High Sierra Released 0.0.18 which should fix this. Thanks to @einstein.42 who helped me test on his Mac. Also added more data for Tag Type 62 for @jca001 Release Notes You will need to manually upgrade or wait until 42 min after the hour. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted March 5, 2018 Author Share Posted March 5, 2018 2 minutes ago, Jimbo said: Released 0.0.18 which should fix this. Thanks to @einstein.42 who helped me test on his Mac. Also added more data for Tag Type 62 for @jca001 Release Notes You will need to manually upgrade or wait until 42 min after the hour. If anyone manually upgraded in the last couple minutes, please do it again. My release failed, but it's all good now. Link to comment Share on other sites More sharing options...
Chioti Posted March 5, 2018 Share Posted March 5, 2018 @Jimbo and @einstein.42 Thank you both in getting it working for the Mac. Now I can get rid of my node red implementation which was updating temp/hum in ISY as variables! Link to comment Share on other sites More sharing options...
