Moblinc Router setup
Today I set up my Son's ISY and also successfully installed the Mobilinc Pro App on his and his wife's Iphones. However I forgot how to get Moblinc work outside of his Wifi network.
Is is sufficient to open the port and set the Mobilinc App to his IP address with the port ?
Edited by asbril
Hi asbril,
While I strongly recommend our MobiLinc Connect service as it'll add in the following features without any changes to your network:
-          Dead easy anywhere access for MobiLinc apps and access via the Admin Console
-          Multi-ISY Support
-          Full Amazon Alexa and Google Home/Google Assistant integration
-          IFTTT Maker support
-          Rich Push notification support for iOS devices
Today View widget support for iOS devices
If you wish to only use a direct IP and manage the network manually, see this link for a high-level overview on port forwarding:
http://forum.mobilinc.com/viewtopic.php?f=6&t=123&sid=d75b7bc6fca453c27b93ecef76c8abbf
Wes
