Moved from Venlink to Nodelink / ISY V5 - Variables + Net Resources ?
So I think I have managed to get Nodeserver and Nodelink working, after moving from 4.62 > 5.012 on ISY.
I have 5 Venstar T5900s that I was using via Venlink, so I ran 5 instances of Venlink from 5 directories.
Also had a slew of ISY variables and network resources assigned to various thermostat / HVAC tasks and monitoring.
So does Nodelink / Nodeserver / ISY V5 eliminate the need for all of this?
Appears that programs have the required parameters right there, with no need to set up net resources etc...
I know this was the promise of V5, but just want to make sure I've got the big picture here (esp. before I delete all those resources / variables).
Thanks for any basic insight.
- And thanks for creating not only the Node... apps, but also the Venlink series. Has served me well.
Yep, shouldn't need any variables or network resources.
Also only need one copy of NodeLink and just add 5 venstar devices.
Awesome - this alone was worth going to V5.
Looks like it will handle my RainMachine also!
Awesome development work and foresight on your part. Thanks!
Quick additional question - had a shortcut to Nodelink in my Windows 10 startup folder, but can't do that with a "run as admin" checked. Won't work when machine re-boots, as I have autologon set up.
So did the elevated command prompt text you put in the server window, and now it works w/o admin rights.
So that will be persistent through re-boots etc?
Not sure what I did entering that command line text...
Edited by telljcl
18 hours ago, io_guy said:
Yep, the cmd is a one-time thing.
OK - thanks. Good news.
Another question as I re-work my programs / variables etc...
I have an old program I used with Venlink which could change the dehumidify setpoint from a low number (basically meaning dehumidify "ON") to a high number (meaning dehumidify "OFF").
So in wanting to rewrite the program for Nodelink, the options I have for "Then" in programs lists only 'Humidity setpoint" - so I don't know if it is dehum or hum.
Also can't figure out if there is a way to just turn "On" or "Off" the dehumidification built in to the Stat - my old venlink programs just changed the % to effectively do that, (because IIRC, venlink couldn't turn ON or OFF the dehumidification function itself, but could change the % at which it activated) but can't see a way to replicate this functionality in the V5 / Nodelink version?
Not sure why I never added setting dehum setpoint.  I'll add it to the next version.
Thanks! That was a great feature of Venlink that I used in a number of programs.
So what do I need to set for "auto update" - in Nodeserver / server PC or Nodelink / ISY, or do I manually update?
I do the updates manually, usingthe automatic feature,  while I am present. There is an auto update checkbox that I turn on when I hear about an update I want. Then I uncheck it after and reboot. There is also ISY update options that I leave enabled.
