Weather portal not working
I haven't been active in a while but all of my HVAC thermostats are conditional based on outside temperature and my weather module is saying 0 degrees even though it's about 80!!
If you look at the weather module what does it say for the last update time? Also is the station you selected correct (the same as before?) Try another station and see what happens ~ also the weather module has been changed to update every 30 minutes from 5.
NOTE: There were changes last year where the controller had to be updated to use the latest firmware. So ensure you're using the latest official release along with the correct Admin Console.
Edited by Teken
Thanks!  I deleted the old location and had it search me out and magically it's back!!!
