Schedule runs at 00:00:00
A couple of you have experienced a bug that causes schedules to start running at 00:00:00 instead of their specified time. This problem will only occur if:
1. You reference a program in another program
2. You delete the referenced program.
You will not notice the problem right away; the schedule will run correctly once more, and then the next time after that it will run at 00:00:00.
This problem is fixed in the next code drop.
Hey Chris -
For the record, per my emails to you I've seen a 00:00:00 bug as well. However, I'm not referencing any programs within my programs.
Different issue?
I pretty sure it is the same issue; the key here is it may occur when you delete a program. The program only had to be referenced once, even for a brief time, then if it was deleted anytime after that you would see the problem.
The good news is the fix will work regardless of what caused it (i.e. referencing a program, deleting a program, etc.).
Glad to hear, can't wait to try it out. It's only happened 2 or 3 times for me, so it has been very infrequent and not reproducable.
