Custom Notifications
Just started using NodeLink after using DSCLink for several years - so far no issues. One thing I haven't figured out yet is my custom notification for the DSC alarm being disarmed - I have a notification working, but how do I show which user disarmed? With DSCLink it was a variable but with NodeLink it seems to be a node attribute. What's the format for using this in a custom notification?
No idea, I don't use notifications.
If ISY V5 doesn't let node defs in notifications you could also move the value to a variable first.
Okay, I figured it out. In case anyone else needs to do this, here's what I did in the UDI Admin console in detail:
1. Figure out the node address for your DSC Alarm node under the Main tab where all the nodes are. For me the node name was "DSC Alarm", and when I selected that node, I could see that the node address was "n001_dsc1".
2. Create a notification customization for this alert (under Configuration -> Emails/Notifications/Customizations). I called mine "AlarmDisarmed" and it contains this in the body:
Home alarm disarmed by user ${sys.node.n001_dsc1.GV1} at ${alert.time12} on ${alert.date}.
(GV1 is the node property for the last user to disarm)
3. Make sure you have email notification set up correctly and working under Configuration -> Emails/Notifications -> Settings/Groups. I'm using "Default"
4. Create a program to alert you. I called mine "AlarmDisarmed", and here's the content:
        'DSC Alarm / Partition 1' Status is Disarmed
        Send Notification to 'Default' content 'AlarmDisarmed'
Now when I disarm the alarm, I get an email like this:
Home alarm disarmed by user 2 at  5:54:26 PM on 2018/05/04
If you need to figure out the right node property for a different type of node, just use the rest interface in a web browser. I went to:
http://<myISYIP>/rest/nodes/n001_dsc1
And was able to see the various properties I could use, though it's not obvious what each one is from this view.
