V0.9.13 - new ecobee security?
This error just started last night. Although I get a stream of these errors  reported now, the data still gets through to ISY mostly.
Complaints about new tokens received from ecobee have continued today despite a NodeLink reboot.
It appears as if  ecobee is changing their access security maybe.
2018-05-09 23:05:01 - Ecobee Web StatusError - InternalServerError [ecobee1]
logfile_2018-05-09.txt
This appears to happen once every hour now. Still functions OK in ISY though.
2018-05-10 06:37:20 - ISY Node Server config detected (profile 1)
2018-05-10 06:37:29 - Ecobee: New tokens received from ecobee.com [ecobee1]
2018-05-10 07:37:39 - Ecobee Web StatusError - InternalServerError [ecobee1]
2018-05-10 07:40:39 - Ecobee: New tokens received from ecobee.com [ecobee1]
2018-05-10 08:40:48 - Ecobee Web StatusError - InternalServerError [ecobee1]
2018-05-10 08:43:48 - Ecobee: New tokens received from ecobee.com [ecobee1]
6 hours ago, io_guy said:
Turn down your log level.
OK Thanks. Which way is down?   IIRC, I had both screen and file logs at Notice.  Currently I have webpage at Notice and file at Debug.
Did I expose something that  really doesn't affect performance/function?
I assume different levels record more or less severity of normal data to errors.
12 minutes ago, io_guy said:
https://en.wikipedia.org/wiki/Syslog#Severity_level
Those errors show up at >= 6.  They're information only - the ecobee tokens expire every hour.
OK cool!
I wondered about that as the token has a 3599 parameter with it triggering a seconds per hour idea. Strange security.
The error report line just before every token issue made me think something was wrong there.
