Micro On/Off ISY Only
Posted (edited)
So am I correct that a micro on/off witch will still operate via ISY control if the 'sense' wires are not connected?
I'm thinking about installing a ceiling fan in my office in place of the ceiling light fixture.  The switch box has no neutral, I can just leave the switch ON and install the micro on/off at the fan and let it turn on/off with the motion sensor that controls the floor lamps.
Edited by jgcharlotte
Posted (edited)
Yes. You'll want to make sure that its specs. 2000 watts, match the fan. Probably ok but I don't know
In related news, I just bought a dimmer version of it because Smarthome is having a 30% off insteon sale through today. MEM18 is the discount code
Paul
Edited by paulbates
It should.  I haven't checked yet, but that's why I went with the on/off, not the open/close. That's over 2.5 HP.   I went ahead and ordered also, with the 30% off and NO SHIPPING.
That rating is for *RESISTIVE* loads (e.g. a space heater or automobile block heater).  Check the ratings carefully for *INDUCTIVE* loads, which would be the motor.  (And for completeness, due to the unique characteristics of a tungsten filament light bulb, there's often a different rating for incandescent lighting loads.)
Ahhh yes, this is true.  I think I've been away from electrical engineering for too long :-)
700W/240VAC Inductive/Capacitive
Should still be fine, but definitely something to look at!
      38k
      379.3k
