James Peterson
Agave for iOS is now available on on the app store.  You can find Agave on the App Store.  All of this can be found in the Agave website, but I have listed the current available features.
Features
Subscription to ISY for realtime updates Included Included Included
SSL Connections Included Included Included
Customizable button and status labels for most devices Included Included Included
Access ISY from home network Included Included Included
Access ISY from outside home network
For example, using Cellular data, or at your work. May require port forwarding on your router, and possibly special service through your Internet service provider
  Included Included
Access ISY via UDI Portal
Requires ISY Portal
Portal Add-On Included
Prioritize connections   Included Included
Multiple ISY connections
Connect to the same ISY more than once, e.x., for "user profiles," or connect to more than one ISY
  Included Included
Securely encrypted and SALTed ISY login data Included Included Included
Optional PIN access to launch profile
If enabled, login data stored on device is encrypted and SALTed with your PIN
Family Access Manager
Add Agave access to your ISY for your friends/family with customizable access level and remote revoke capabilities. Also useful to share your Agave purchase on Android with your iOS devices or vice-versa!
Add Family Manager
Device Support
ISY Scenes Included Included Included
On/Off Switch Relay Included Included Included
Dimmer Switch Included Included Included
IO Linc Sensor/Relay Included Included Included
Triggerlinc Open/Close sensor Included Included Included
Motion sensors Included Included Included
Smoke sensor Included Included Included
LED light bulbs (INSTEON, Z-Wave) Included Included Included
Door locks (Z-Wave, INSTEON Lock Controller) Included Included Included
Sprinklers (EZFlora/EZRain) Sprinkler Add-On Included
Variables and Programs
Run programs in all conditions; customizable variables; custom naming for app-readable variables, standard input, toggle (ON/OFF); customizable status and buttons options; slider; customizable min and max values
Variable/Program Add-On Included
Thermostats
Control and navigate thermostat controls
Thermostat Add-On Included
ELK M1 Security (may be minor differences between iOS and Android right now)
Control and manage your ELK M1 control through your ISY: Arm/disarm areas and view zone statues, control all output functionality, custom naming for better app viewing, ON/OFF controls, optional auto-off timer, momentary control
  • 1 month later...
Hi there, great app! A really nice viable alternative to other older apps.
Quick question, do you have the concept of a floor plan or rooms? I'm trying to figure out if you do but it doesn't seem like it. Also, there's no way to modify the native groupings correct? Would be really great if the groups and assignments could be user defined.
I'm very excited about your product and would be happy to support it in any way with feedback/testing etc.
No floor plan as of yet.  I have thought about this for a possible spin off secondary app, but just don't have the time right now.
Groupings?  Do you mean Rooms or Folders as the ISY has them.  If so, that will be in the next release.
Got it!
I actually think it would be just as helpful as perhaps not as big of a change if you support multiple pages in home that you could swipe left/right to or jump to by clicking on the page header?
Easier said than done of course.
Yes exactly regarding the groupings in ISY.
Really great app though thanks for all your work.
By the way, just a cosmetic change, I think it would be quite useful to support different colors in the
Sorry meant to say different colors in the Home cards depending on status. It’s useful for things like doors etc to visually quickly recognize the status of objects.
Looks interesting Efren, downloaded, but cannot get trial to work..
Are you able to get logged in?
Have you ever used the Android version of Agave?
What error are you getting?
Sent from my Nexus 5X using Tapatalk
I have used the Android version ages ago, but unless the logon id is being sent up for the ISY - the accounts are not connected.  (using the local network - options)
No error, just no option for trial that i can see..
Kk. The trial is now no longer using the login ids. GDPR reasons. It is using a hashed ISY ID. This links the iOS and Android trials together. I'll probably change this a bit when I have time. In the meantime, send me a support email to support@agaveha.com with your ISY UUID and I can extend your trial so you can give it a try.
15 hours ago, PurdueGuy said:
Woohoo!  My beeping is back!  (or it will be once I am done!)
Thanks - sent email.
Steve
