RainMachine: Not responding to all functions from AC
Rainmaching will not execute certain functions from the admin console and ISY programs.  I have a "hotzones" RM program that an ISY program calls based on certain criteria. The ISY Program does run, but nothing happens when its then statement is called.
        Set 'Yard / Sprinklers / Program - Hot Zones - Manual ' Start
When I try to run the "hotzones" RM program from the Admin Console, I get:
Heartbeat is working, and when the RM does something like run a program internally, turn on a zone, the ISY sees that and is up to date. Things like the configuration drops downs in the console all seem to work and show up with the correct settings in the RM interface when changed.
I turned on debug level logging for the RM, all it shows is the access code at start up, and if the RM has a change to report. Just a few status lines. I have 2 venstar tstats  and they operate them normally from the Admin Console and ISY programs.
Paul
Please turn on ISY debug (under NodeLink System Config tab) so I can see what the ISY is sending for that command.
io_guy
Ok, here it is from a nodelink reboot. The very last lines are when I pressed the run button for my RM hotzones program.
2018-08-05 21:07:09 - ISY Send: Variable rainmachi-GV1 added to queue (Val: -1, QS: 28)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi-GV2 added to queue (Val: 0, QS: 29)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi-GV3 added to queue (Val: 0, QS: 30)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi-GV4 added to queue (Val: 0, QS: 31)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi_p1-ST added to queue (Val: 0, QS: 32)
2018-08-05 21:07:09 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/GV3/0/25)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi_p1-GV1 added to queue (Val: 0, QS: 33)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi_p1-GV2 added to queue (Val: 1, QS: 33)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi_p1-GV3 added to queue (Val: 2, QS: 34)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi_p2-ST added to queue (Val: 0, QS: 35)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi_p2-GV1 added to queue (Val: 3, QS: 36)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi_p2-GV2 added to queue (Val: 1, QS: 37)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi_p2-GV3 added to queue (Val: 1, QS: 38)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi_p3-ST added to queue (Val: 0, QS: 39)
2018-08-05 21:07:09 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/ST/76.0/14)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi_p3-GV1 added to queue (Val: 3, QS: 39)
2018-08-05 21:07:09 - ISY Send: Variable rainmachi_p3-GV2 added to queue (Val: 0, QS: 40)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_p3-GV3 added to queue (Val: 0, QS: 41)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z1-ST added to queue (Val: 0, QS: 42)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z2-ST added to queue (Val: 0, QS: 43)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z3-ST added to queue (Val: 0, QS: 44)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z4-ST added to queue (Val: 0, QS: 45)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z5-ST added to queue (Val: 0, QS: 46)
2018-08-05 21:07:10 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/CLISPC/75.0/14)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z6-ST added to queue (Val: 0, QS: 46)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z7-ST added to queue (Val: 0, QS: 47)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z8-ST added to queue (Val: 0, QS: 48)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z9-ST added to queue (Val: 0, QS: 49)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z10-ST added to queue (Val: 0, QS: 50)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z11-ST added to queue (Val: 0, QS: 51)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z12-ST added to queue (Val: 0, QS: 52)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z13-ST added to queue (Val: 0, QS: 53)
2018-08-05 21:07:10 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/CLISPH/68.0/14)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z14-ST added to queue (Val: 0, QS: 53)
2018-08-05 21:07:10 - ISY Send: Variable rainmachi_z15-ST added to queue (Val: 0, QS: 54)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-CLIMD added to queue (Val: 2, QS: 55)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-CLIHCS added to queue (Val: 0, QS: 56)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-CLIFS added to queue (Val: 0, QS: 57)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-CLIFRS added to queue (Val: 0, QS: 58)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-CLISMD added to queue (Val: 0, QS: 59)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-GV3 added to queue (Val: 0, QS: 60)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-ST added to queue (Val: 75.0, QS: 61)
2018-08-05 21:07:10 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/CLIHUM/55/51)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-CLISPC added to queue (Val: 74.0, QS: 61)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-CLISPH added to queue (Val: 68.0, QS: 62)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-CLIHUM added to queue (Val: 62, QS: 63)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-GV2 added to queue (Val: -1, QS: 64)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-GV6 added to queue (Val: 0, QS: 65)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-GV1 added to queue (Val: 35, QS: 66)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-GV7 added to queue (Val: 0, QS: 67)
2018-08-05 21:07:10 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/GV2/-1/25)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-GV5 added to queue (Val: 60, QS: 68)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr-GV4 added to queue (Val: 0, QS: 68)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_run-GV1 added to queue (Val: 1533503693, QS: 69)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_run-GV2 added to queue (Val: 0, QS: 70)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_run-GV3 added to queue (Val: 0, QS: 71)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_run-GV4 added to queue (Val: 415, QS: 72)
2018-08-05 21:07:10 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/GV6/0/25)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_run-GV5 added to queue (Val: 0, QS: 73)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_run-GV6 added to queue (Val: 0, QS: 73)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_run-GV7 added to queue (Val: 0, QS: 74)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_run-GV8 added to queue (Val: 0, QS: 75)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_run-GV9 added to queue (Val: 35.41, QS: 76)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_s00-ST added to queue (Val: 75.0, QS: 77)
2018-08-05 21:07:10 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/GV1/27/51)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_s00-GV1 added to queue (Val: , QS: 78)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_s02-ST added to queue (Val: 76.0, QS: 78)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_s02-GV1 added to queue (Val: 68, QS: 79)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_s01-ST added to queue (Val: 84.0, QS: 80)
2018-08-05 21:07:10 - ISY Send: Variable venstarfr_s01-GV1 added to queue (Val: 100, QS: 81)
2018-08-05 21:07:10 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/GV7/0/25)
2018-08-05 21:07:10 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/GV5/60/51)
2018-08-05 21:07:11 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/GV4/0/25)
2018-08-05 21:07:11 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_run/report/status/GV1/1533503694/25)
2018-08-05 21:07:11 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_run/report/status/GV2/0/25)
2018-08-05 21:07:11 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_run/report/status/GV3/0/25)
2018-08-05 21:07:11 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_run/report/status/GV4/225/25)
2018-08-05 21:07:11 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_run/report/status/GV5/0/25)
2018-08-05 21:07:11 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_run/report/status/GV6/0/25)
2018-08-05 21:07:11 - ISY Send: Variable isydata-GV1 added to queue (Val: 21, QS: 73)
2018-08-05 21:07:11 - ISY Send: Variable isydata-GV2 added to queue (Val: 7, QS: 74)
2018-08-05 21:07:12 - ISY Send: Variable isydata-GV3 added to queue (Val: 312307, QS: 75)
2018-08-05 21:07:12 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_run/report/status/GV7/0/25)
2018-08-05 21:07:12 - ISY Send: Variable isydata-GV4 added to queue (Val: 1, QS: 76)
2018-08-05 21:07:12 - ISY Send: Variable isydata-GV5 added to queue (Val: 32, QS: 76)
2018-08-05 21:07:12 - ISY Send: Variable isydata-GV6 added to queue (Val: 0, QS: 77)
2018-08-05 21:07:12 - ISY Send: Variable isydata-GV7 added to queue (Val: 8, QS: 78)
2018-08-05 21:07:12 - ISY Send: Variable isydata-GV8 added to queue (Val: 5, QS: 79)
2018-08-05 21:07:12 - ISY Send: Variable isydata-GV9 added to queue (Val: 2018, QS: 80)
2018-08-05 21:07:12 - ISY Send: Variable isydata-GV10 added to queue (Val: 217, QS: 81)
2018-08-05 21:07:12 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_run/report/status/GV8/0/25)
2018-08-05 21:07:12 - ISY Send: Variable isydata-GV11 added to queue (Val: 2, QS: 82)
2018-08-05 21:07:12 - ISY Send: Variable isydata-GV12 added to queue (Val: 1, QS: 82)
2018-08-05 21:07:12 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_run/report/status/GV9/27.82/10)
2018-08-05 21:07:12 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_s00/report/status/ST/76.0/14)
2018-08-05 21:07:12 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_s00/report/status/GV1//25)
2018-08-05 21:07:12 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_s03/report/status/ST/75.0/14)
2018-08-05 21:07:12 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_s03/report/status/GV1/66/25)
2018-08-05 21:07:12 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_s01/report/status/ST/84.0/14)
2018-08-05 21:07:13 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus_s01/report/status/GV1/100/25)
2018-08-05 21:07:13 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi/report/status/ST/0/25)
2018-08-05 21:07:13 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi/report/status/GV1/-1/25)
2018-08-05 21:07:13 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi/report/status/GV2/0/25)
2018-08-05 21:07:13 - Web Request: /isylink/nodes/n001_venstarus/cmd/CLIFS/0/68
2018-08-05 21:07:13 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi/report/status/GV3/0/25)
2018-08-05 21:07:13 - ISY Send: Variable venstarus-GV2 added to queue (Val: 1, QS: 72)
2018-08-05 21:07:13 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi/report/status/GV4/0/25)
2018-08-05 21:07:13 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_p1/report/status/ST/0/25)
2018-08-05 21:07:13 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_p1/report/status/GV1/0/25)
2018-08-05 21:07:14 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_p1/report/status/GV2/1/25)
2018-08-05 21:07:14 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_p1/report/status/GV3/2/25)
2018-08-05 21:07:14 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_p2/report/status/ST/0/25)
2018-08-05 21:07:14 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_p2/report/status/GV1/3/25)
2018-08-05 21:07:14 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_p2/report/status/GV2/1/25)
2018-08-05 21:07:14 - Web Request: /isylink/nodes/n001_venstarfr/cmd/CLIFS/0/68
2018-08-05 21:07:14 - ISY Send: Variable venstarfr-GV2 replaced in queue (Val: 1, QS: 64)
2018-08-05 21:07:14 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_p2/report/status/GV3/1/25)
2018-08-05 21:07:14 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_p3/report/status/ST/0/25)
2018-08-05 21:07:14 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_p3/report/status/GV1/3/25)
2018-08-05 21:07:15 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_p3/report/status/GV2/0/25)
2018-08-05 21:07:15 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_p3/report/status/GV3/0/25)
2018-08-05 21:07:15 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z1/report/status/ST/0/25)
2018-08-05 21:07:15 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z2/report/status/ST/0/25)
2018-08-05 21:07:15 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z3/report/status/ST/0/25)
2018-08-05 21:07:15 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z4/report/status/ST/0/25)
2018-08-05 21:07:15 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z5/report/status/ST/0/25)
2018-08-05 21:07:15 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z6/report/status/ST/0/25)
2018-08-05 21:07:16 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z7/report/status/ST/0/25)
2018-08-05 21:07:16 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z8/report/status/ST/0/25)
2018-08-05 21:07:16 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z9/report/status/ST/0/25)
2018-08-05 21:07:16 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z10/report/status/ST/0/25)
2018-08-05 21:07:16 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z11/report/status/ST/0/25)
2018-08-05 21:07:16 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z12/report/status/ST/0/25)
2018-08-05 21:07:16 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z13/report/status/ST/0/25)
2018-08-05 21:07:17 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z14/report/status/ST/0/25)
2018-08-05 21:07:17 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi_z15/report/status/ST/0/25)
2018-08-05 21:07:17 - Web Request: /index.htm
2018-08-05 21:07:17 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/CLIMD/2/67)
2018-08-05 21:07:17 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/CLIHCS/0/25)
2018-08-05 21:07:17 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/CLIFS/0/68)
2018-08-05 21:07:17 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/CLIFRS/0/80)
2018-08-05 21:07:17 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/CLISMD/0/25)
2018-08-05 21:07:17 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/GV3/0/25)
2018-08-05 21:07:18 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/ST/75.0/14)
2018-08-05 21:07:18 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/CLISPC/74.0/14)
2018-08-05 21:07:18 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/CLISPH/68.0/14)
2018-08-05 21:07:18 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/CLIHUM/62/51)
2018-08-05 21:07:18 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/GV2/1/25)
2018-08-05 21:07:18 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/GV6/0/25)
2018-08-05 21:07:18 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/GV1/35/51)
2018-08-05 21:07:18 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/GV7/0/25)
2018-08-05 21:07:19 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/GV5/60/51)
2018-08-05 21:07:19 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/GV4/0/25)
2018-08-05 21:07:19 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_run/report/status/GV1/1533503693/25)
2018-08-05 21:07:19 - Web Request: /index.htm
2018-08-05 21:07:19 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_run/report/status/GV2/0/25)
2018-08-05 21:07:19 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_run/report/status/GV3/0/25)
2018-08-05 21:07:19 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_run/report/status/GV4/415/25)
2018-08-05 21:07:19 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_run/report/status/GV5/0/25)
2018-08-05 21:07:20 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_run/report/status/GV6/0/25)
2018-08-05 21:07:20 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_run/report/status/GV7/0/25)
2018-08-05 21:07:20 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_run/report/status/GV8/0/25)
2018-08-05 21:07:20 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_run/report/status/GV9/35.41/10)
2018-08-05 21:07:20 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_s00/report/status/ST/75.0/14)
2018-08-05 21:07:20 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_s00/report/status/GV1//25)
2018-08-05 21:07:20 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_s02/report/status/ST/76.0/14)
2018-08-05 21:07:20 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_s02/report/status/GV1/68/25)
2018-08-05 21:07:21 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_s01/report/status/ST/84.0/14)
2018-08-05 21:07:21 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr_s01/report/status/GV1/100/25)
2018-08-05 21:07:21 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV1/21/25)
2018-08-05 21:07:21 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV2/7/25)
2018-08-05 21:07:21 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV3/312307/25)
2018-08-05 21:07:21 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV4/1/25)
2018-08-05 21:07:21 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV5/32/25)
2018-08-05 21:07:22 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV6/0/25)
2018-08-05 21:07:22 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV7/8/47)
2018-08-05 21:07:22 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV8/5/25)
2018-08-05 21:07:22 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV9/2018/25)
2018-08-05 21:07:22 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV10/217/25)
2018-08-05 21:07:22 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV11/2/25)
2018-08-05 21:07:22 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV12/1/25)
2018-08-05 21:07:22 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/GV2/1/25)
2018-08-05 21:07:30 - ISY Send: Variable rainmachi-GV1 added to queue (Val: 1, QS: 1)
2018-08-05 21:07:30 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi/report/status/GV1/1/25)
2018-08-05 21:07:32 - ISY Send: Variable isydata-GV3 added to queue (Val: 312308, QS: 1)
2018-08-05 21:07:32 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV3/312308/25)
2018-08-05 21:07:40 - ISY Send: Variable venstarus-GV2 added to queue (Val: -1, QS: 1)
2018-08-05 21:07:40 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/GV2/-1/25)
2018-08-05 21:07:44 - ISY Send: Variable venstarfr-GV2 added to queue (Val: -1, QS: 1)
2018-08-05 21:07:44 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarfr/report/status/GV2/-1/25)
2018-08-05 21:07:51 - ISY Send: Variable rainmachi-GV1 added to queue (Val: -1, QS: 1)
2018-08-05 21:07:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi/report/status/GV1/-1/25)
2018-08-05 21:08:01 - Web Request: /isylink/nodes/n001_rainmachi_p2/cmd/START
2018-08-05 21:08:02 - ISY Send: Variable isydata-GV2 added to queue (Val: 8, QS: 1)
2018-08-05 21:08:02 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_isydata/report/status/GV2/8/25)
2018-08-05 21:08:07 - ISY Send: Variable venstarus-GV2 added to queue (Val: 1, QS: 1)
2018-08-05 21:08:07 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_venstarus/report/status/GV2/1/25)
2018-08-05 21:08:13 - ISY Send: Variable rainmachi-GV1 added to queue (Val: 1, QS: 1)
2018-08-05 21:08:13 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rainmachi/report/status/GV1/1/25)
2018-08-05 21:08:14 - Web Request: /index.htm
Paul
Yep,
I broke it adding the last feature.  Will fix.
Sorry for the delay.  I fixed it but have been away.  Will get a new release out Wednesday.
