ZRC-90 Scene Remote
I've just got a Remotec ZRC-90 from Amazon - https://www.amazon.com/ZRC-90US-BW8510US-Remotec-Cert-ZC10-15100007/dp/B016YTTIVW
Manual is here - https://www.remotec.com.hk/wp-content/uploads/2016/06/8510_UM_V1.01_F820-8510-0000_20151113.pdf
I'm adding it to my ISY, and it's appearing as a single node with just a battery status. I can't seem to get to the 8 buttons to display? I want to use them as triggers for programs.
Has anyone tried this?
Can anyone recommend a different remote?
Matt
Thanks lilyoyo1.
  • Firmware - 4.7.3
  • UI - 4.7.3
  • Z-wave version - 4.55
@MattJ, You will need to upgrade your firmware to 5.0.13D to get the multi-channel capability that you need for the additional nodes.
Belo is the link to upgrade your firmware.
Thank you so much. The update allowed the 8 scene buttons to be visible.
Strangely though, the scene buttons are only usable in the programs before the first time the button is pressed after inclusion; then they just start disappearing from the list of controls in the IF part of the program. Weird.
5.0.13D is still beta firmware. You should report this in the appropriate thread so that issues can be fixed.
