Keypad LED lighting
I am sure the answer is simple.  I have a 6 button keypad that won't reliably turn on the LED back lighting when the load is switched on or off for example or when a program is supposed to turn the LED back lighting "on" upon an event.  I am a little confused by the programming for the LED settings.  Advice welcome.  Many thanks.
Are you turning ON a scene that includes the button, or trying to adjust the default backlight settings?  (Sounds as if the latter.)  Feel free to post the program, but I suspect you should istead be turning the button ON rateher than adjusting the backlighting.
If the load is a separate device, i.e. not physically connected to the keypad, then you need to create a scene and add both devices into the scene as CONTROLLERS.
When any device in a scene is turned on or off it also triggers all devices in that scene.
Thanks for the replies.  Just to clarify, I want one of the non-load buttons (A, B, C or D) to light up when the garage door sensor is off and to go off when it is "on".  I also want another button to light up when downstairs lights are on so I can hit that button to turn them off from upstairs. Then I want that button's LED light to turn off.
Here is some code....
IF
  • From    Sunset
  • To      Sunrise (next day)
  • And Status 'Garage / 3D.E4.0D-Sensor' is Off
  • Set 'Outside / House Front (load)' On
  • Set 'Main Floor / Kitchen Garage Key' On  5 / Off 0 (Backlight Level)
  •         Set 'Outside / House Front (load)' Off
  •         Set 'Main Floor / Kitchen Garage Key' On  0 / Off 0 (Backlight Level)
I dont really understand the On/Off backlight levels.  Can you suggest the correct code to use.  Many thanks.
Your program is adjusting the default backlight levels for on/off, rather than turning the button on or off.
I would take the approach suggested by techman...create a scene with the sensor as controller and keypad button as responder.  Eliminate the current program.
For the downstairs lights, I might do the same thing, but it would depend on how many lights, how they are controlled, and the logic you want to employ.  If all are currently controlled by a single switch or single scene, then create a scene with switch as controller and button as responder.
If you must use programs because of additional logic needed, then create a scene with the KPL button only included.  In your current programs, replace the action that sets the backlight levels with an action that turns on/off the scene, as appropriate.
KPL backlights can be level adjusted from programs but to turn them on or Off you need to create a scene for each state. These scenes can then be operated by an included controlling status (device in the scene) or by a program.
Thanks for the replies.  Very helpful and I have the keypad now working as I need it to.
Edited by UD2)17rrh
Text.
