October 8, 20187 yr On a whim I decided to rename "My ISY" to a name including an "@" . There was no indication of any issues until I went to log in the next time. Now I'm consistently getting this error when I attempt to start the Admin Console from ISY Launcher. I suspect the ampersand is the causing trouble as a delimiter. FYI I am running 5.0.1D. How can I get by this?
October 9, 20187 yr Note:s ampersand = '&' , at symbol = '@' , delimiter is a symbol placed at the end of data to tell a parser when to stop. So the question is how to get access to remove the '@' symbol again?
October 9, 20187 yr 1 hour ago, DaveStLou said: On a whim I decided to rename "My ISY" to a name including an "@" . There was no indication of any issues until I went to log in the next time. Now I'm consistently getting this error when I attempt to start the Admin Console from ISY Launcher. I suspect the ampersand is the causing trouble as a delimiter. FYI I am running 5.0.1D. How can I get by this? Try to Telnet into your ISY https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Telnet_To_Your_ISY
October 9, 20187 yr Author 1 hour ago, Techman said: Try to Telnet into your ISY https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Telnet_To_Your_ISY Okay I've Telnet'd in but to @larryllix point, how do i rename the ISY now that I'm in? That's not one of the Menu choices.
October 9, 20187 yr Author I figured out that I could rename it through the Dashboard. It's back to old reliable My ISY and accessible via Admin Console.
March 8, 20197 yr I'm getting the same error message trying to get into the Admin Console after renaming My Lighting to a different name. Telnet did not fix this. The new name shows up in ISY Launcher and Mobilinc. I can also still operate the system through Mobilinc and I can launch Dashboard. Dashboard gives the same error, but allows me to login and run Dashboard. Any thoughts on this? Seems like this change should be pretty straight forward.
March 8, 20197 yr Author 4 hours ago, mbking said: I'm getting the same error message trying to get into the Admin Console after renaming My Lighting to a different name. Telnet did not fix this. The new name shows up in ISY Launcher and Mobilinc. I can also still operate the system through Mobilinc and I can launch Dashboard. Dashboard gives the same error, but allows me to login and run Dashboard. Any thoughts on this? Seems like this change should be pretty straight forward. Launch Dashboard and then right click on the name you gave it in the upper left corner. You'll see Rename in the menu that pops up: Type in the new name and click OK
March 8, 20197 yr 3 hours ago, DaveStLou said: Launch Dashboard and then right click on the name you gave it in the upper left corner. You'll see Rename in the menu that pops up: Type in the new name and click OK Thanks for the help DaveStLou. I tried this last night, but for me, it didn't fix the problem. Rebooting the ISY did the trick. I'm not sure what I did differently. I'm running the Dashboard on my iMac and the Dashboard behaves a little differently. I see the top level folder, but no name next to it. Again, thanks for the help. All is right with the world again.
