Green 10101 Icon will not go away
Is this issue still pending? I just purchased two Zooz ZEN25 and the primary nodes are stuck in 11010 "write changes" very similar to this. They also seem to have periodic errors communicating.
I recently purchased a Zooz 22 and have the same green "write changes" indicator and am unable to actually write that 'supposed' change to the device. However the switch works fine, so no worries for me other than the green indicator.
Interesting, I had all kinds of problems after adding 2 ZEN25. I just removed them and things appear much better.  I also have a ZEN15 that I just added at the same time, which seems to behave. It makes me sad that the ISY ends up as a third class controller for modern ZWave devices. :(
Edited by nathan
  • 2 months later...
Was this issue ever resolved. I seem to have the same problem. Is there any way to better debug where the offending node is?
  • 1 month later...
The green 1011 means that there are pending writes for that device. If it's a hard wired device then right click on the device and then click on write updates. If it's a battery operated device you need to first manually put the device into the linking mode before writing the updates.
  • 1 month later...
The issue with everyone in this thread is that they have tried to write updates and doesn't not clear the green icon. I just added a Zen25 double plug and 3 of the nodes are green icon which will not clear I have tried removing and re-adding and same thing still happens.
Here is a picture of what I mean...
Also off-topic the Zen25 has a .3 node On-Off Power switch that doesn't appear to do anything
I tried removing and adding again after posting and the green 11011 appeared again after a few minutes but only on the first three nodes. Doesn't affect operation of switch but would be nice to turn them off because is cosmetic.
Edited by brians
I updated to 5.0.16 and the green icons are no longer beside those nodes. Will see if they come back eventually.
I added the same ZEN25 last night for validating and I had the writing icons as well.  However I did reboot that ISY last night and the writing icons are gone and have not come back.  I don't think rebooting is the "correct" way to handle this but I thought I'd share what I found.
Do you have any other powered devices in the same area?  Have you ran any queries against the plug to see if they all work or if any of them fail?
queries work fine when it has the green icons even. I have a couple Leviton plugs in another room and they are all fine.
I recently just started last year with Z-Wave (I am primarily Insteon). The only Z-Wave devices I have are:
2x Levion plug in switch
1x Levion plug in lamp dimmer
WaterCop
EverSpring Water sensor
Yale Assure SL Lock.. works reliable and reports to ISY every time is locked/unlocked but sometimes I get timeouts when reading (believe is a wakeup issue and ISY times out)
ZEN25  Double Plug
I am looking at Double Plug now and is fine after I rebooted last night. I can see the last node turning on/off every second or so because I still have a USB device plugged into it which is fully charged. I did some Queries and there are never any errors.
I added another Z-Wave plus device tonight. A ZLINK PD-100 Plug-In Dimmer. It works real good but has the 10101 Green icon beside it. Rebooting ISY does not make it go away like it does with the ZEN25. I tried writing updates to it and Z-Wave synchronize, even Heal, which don't fix it.
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ] ----------------------------------------------
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ] Master Bedroom Lamp
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ] ZW015_1 uid=15 type=4.17.1 mid=789 tid=18244 pid=12338
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x5E  V2   ZWAVEPLUS_INFO
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x26  V4   SWITCH_MULTILEVEL
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x86  V3   VERSION
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x55  V2   TRANSPORT_SERVICE
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x72  V2   MANUFACTURER_SPECIFIC
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x70  V3   CONFIGURATION
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x85  V2   ASSOCIATION
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x59  V1   ASSOCIATION_GROUP_INFO
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x73  V1   POWERLEVEL
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x2C  V1   SCENE_ACTUATOR_CONF
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x2B  V1   SCENE_ACTIVATION
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x5A  V1   DEVICE_RESET_LOCALLY
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x9F  V1   SECURITY_2
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x6C  V1   SUPERVISION
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ]    -  x7A  V4   FIRMWARE_UPDATE_MD
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ] - Secure
Wed 10/16/2019 09:26:22 PM : [ZW-SHOW         ] Last working route from ISY to Node  15 - Master Bedroom Lamp
Wed 10/16/2019 09:26:23 PM : [ZW-SHOW         ] Node  15 - Master Bedroom Lamp has the following neighbors
Wed 10/16/2019 09:26:23 PM : [ZW-SHOW         ]    - Repeater - Node   3 - WaterCopZ
Wed 10/16/2019 09:26:23 PM : [ZW-SHOW         ]    -          - Node   8 - Front Door
Wed 10/16/2019 09:26:23 PM : [ZW-SHOW         ]    - Repeater - Node  14 - ZW 014 On-Off Power Switch
Wed 10/16/2019 09:26:23 PM : [ZW-SHOW         ] Node  15 - Master Bedroom Lamp has 1 association group
Wed 10/16/2019 09:26:23 PM : [ZW-SHOW         ]    Associations for group 001 of ZW015_1 Master Bedroom Lamp
Wed 10/16/2019 09:26:23 PM : [ZW-SHOW         ]    Max Associations = 1
Wed 10/16/2019 09:26:23 PM : [ZW-SHOW         ]       - Node   1 - [This ISY]
Wed 10/16/2019 09:26:23 PM : [ZW-SHOW         ] ----------------------------------------------
Edited by brians
My ZLINK PD-100 I think I solved. I was adding to a Scene with an Insteon KeypadLinc button and was trying to make it a controller also for some reason.
Making it a responder doesn't add the green 10101 icon.
Edit... spoke too soon, just noticed a the green icon next to it.
Wish there was a way to turn off those icons, or at least determine what ISY wants to write to them.
But in this case an ISY reboot clears the icon where it did not before when I tried to add as a controller in a scene.
Edited by brians
