IRLinc error
I was linking buttons into IRLinc when I got an error message the ISY was trying to find nodes. Now on admin console IRLinc and all buttons linked have the green football on them. What did I do wrong and how can I fix it? Thanks
IRLinc 2411R IR receiver or 2411T IR transmitter?
Are you using the Link Management choices to add a node to the receiver or transmitter?
The Green Barrels. Do they have a 11011 inside the green circle? That indicates a Write Updates to the device is needed. You should be able to click on one of the green  barrels and start a write updated to that node. You can do it for each one.
If you have a PRO version of the ISY994i is the automatic writes off?
Edited by Brian H
Add information
It's a IRLinc receiver, I'm using link management to link the buttons, it was all working fine, I then added a few more links when it did this. I've tried writing updates to the IR Linc and linked buttons but the green barrel appears again after the process
I'm puzzled, last night I tried writing updates to the IRLinc and all the buttons with no joy, tried it again just now starting with the IRLinc itself and then the buttons individually and after I did one of those all seems fine.
Well the IRLinc is a power line only module. If there was intermittent noise or a signal sucker. That could have caused some issues.
My information may have been sketchy. Modules with more than one button. You write updates to the main module in the list. That usually does all of them.
