Red !, but appears to have communicated
I know the power supply that the outdoorlink (4e.01.2b)is controller causes this, but from looking at the logs it sure looks like an answer comes along in a few seconds here.  If the outdoorlinc is off, it responds instantly.  Since it's an outdoorlink, sticking a filter in here is tricky as they are not outdoor rated.
Thu 11/22/2018 05:43:52 AM : [INST-TX-I1  ] 02 62 4E 01 2B 0F 19 00
Thu 11/22/2018 05:43:52 AM : [INST-ACK    ] 02 62 4E.01.2B 0F 19 00 06          LTSREQ (LIGHT)
Thu 11/22/2018 05:44:01 AM : [INST-TX-I1  ] 02 62 4E 01 2B 0F 19 00
Thu 11/22/2018 05:44:01 AM : [INST-ACK    ] 02 62 4E.01.2B 0F 19 00 06          LTSREQ (LIGHT)
Thu 11/22/2018 05:44:06 AM : [INST-SRX    ] 02 50 4E.01.2B 19.72.DE 2B 00 FF           (FF)
Thu 11/22/2018 05:44:06 AM : [Std-Direct Ack] 4E.01.2B-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Thu 11/22/2018 05:44:10 AM : [INST-TX-I1  ] 02 62 4E 01 2B 0F 19 00
Thu 11/22/2018 05:44:10 AM : [INST-ACK    ] 02 62 4E.01.2B 0F 19 00 06          LTSREQ (LIGHT)
Thu 11/22/2018 05:44:48 AM : [INST-SRX    ] 02 50 4E.01.2B 19.72.DE 2B 00 FF           (FF)
Thu 11/22/2018 05:44:48 AM : [Std-Direct Ack] 4E.01.2B-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
The Red ! maybe from the  3AM Query All program. That queries all the modules for their present status.
If the load is off and you get a faster response. As you though. The load when on is making power line noise. If you can test it with the load disconnected and it is better. That would also indicate the load is making problems when on.
If you click on the module when the Red ! is showing. If you do a query on the module when the load is on. Does it still stay Red !?
Edited by Brian H
