2441TH THermostat States
I have a 2441TH thermostat that is giving me problems.
If I switch from heat mode to Auto mode the time of day state - wake/away/return/sleep does not update to the correct state unless I start pressing time or program buttons.
Example, I get up before wake scheduled  time and set thermostat to "HEAT mode so the furnace comes on, Then during the wake schedule I switch the thermostat to "AUTO" it does not update to wake and stays at sleep until I press the time or program buttons.
Anyone else experience this or have a solution
Todd
  • 1 month later...
I have the same issue. I believe its related to the thermostat firmware not the isy
It was actually a defective unit and was replaced by the vendor. Replacement works fine although it takes a few minutes for it to switch to correct schedule
