New ISY994i ZW+IR Pro - program - Not Loaded - Out of Memory - Fixed
New ISY994i ZW+IR Pro out of the box 30 minutes ago, added device 2477S (labeled Switch) and I can turn it on / off no problem
Then I wrote a simple program to turn switch on a set time.
When I saved the program, the status shows
There are a couple of other posts in this forum with similiar title, but nothing that helps me understand what the issue is.
Can someone help explain the issue ?
Remove power then remove and reinstall the SD card.
If that fails, and you have a spare card, try that. If that is it UDI will send you a replacement.
Was not aware there is an SD card ... very difficult to remove, but done and same issue ... I have no SD cards
Still confused, memory test shows good, but SD card is an 8GB ... what happend to the extra 4GB memeory ?
Fixed  ...  somehow I installed the wrong ISY Launcher
support@universal-devices.com wrote:
Please make sure you are using the same UI/Firmware version. I suspect you are using UI 4.7.3 whereas your ISY is 5.0.13. Here are the instructions:
https://wiki.universal-devices.com/index.php?title=Main_Page#Installing_the_Admin_Console_Icon_on_Your_Desktop
This was a HUGE help, Jim - thank you!  Being a newb I get lost in about 3 seconds.  I understood the notion of having the UI and firmware match, but deciphering HOW to make that happen wasn't easy...  I still have much to learn - sure appreciate your posts!  John
