Insteon Ramp Rate
I'd like to be able to send an "On" command, via program, to an Insteon 2477D and have it use a ramp rate of four minutes.  If I turn the light on from the switch itself, the full ramp rate is executed.  If I do it from a program, it comes on immediately.  I must be using the wrong syntax in the set on command.  Can anyne help?  Thanks.
JLOB
JLOB
Create a scene for the device as a responder only. Enter the 4 minute ramp rate in the scene. Turn the scene on with the program, rather than the switch.
Paul
Thank you.  Not sure why didn't think of that, but I'm grateful.
JLOB
