markv58 Posted December 22, 2018 Share Posted December 22, 2018 I'm not getting any updates to the ISY without restarting the Nodeserver on rPi since updating to 2.0.11. I have gone back to 2.0.5 until this is all resolved. I'm mostly data mining for various operations. Thanks for all the hard work! Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted December 22, 2018 Author Share Posted December 22, 2018 I'm not getting any updates to the ISY without restarting the Nodeserver on rPi since updating to 2.0.11. I have gone back to 2.0.5 until this is all resolved. I'm mostly data mining for various operations. Thanks for all the hard work! There should not be any issue with getting updates, I'll need a log package to try to debugSent from my Pixel 3 XL using Tapatalk Link to comment Share on other sites More sharing options...
markv58 Posted December 23, 2018 Share Posted December 23, 2018 42 minutes ago, Jimbo said: There should not be any issue with getting updates, I'll need a log package to try to debug Sent from my Pixel 3 XL using Tapatalk I had to delete then reinstall on the 20th due to a rogue node after the update. I did clean the node slot (8) with mongo before the reinstall. 2.0.5 is in slot (12) with a slight overlap before I stopped the other instance today. Ecobee_logs_2018-12-22 17_31_16.zip Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted December 23, 2018 Author Share Posted December 23, 2018 1 hour ago, markv58 said: I had to delete then reinstall on the 20th due to a rogue node after the update. I did clean the node slot (8) with mongo before the reinstall. 2.0.5 is in slot (12) with a slight overlap before I stopped the other instance today. Ecobee_logs_2018-12-22 17_31_16.zip Yes I see that 2.0.11 was started at: 2018-12-22 12:40:21,540 [NodeServer] [INFO ] Ecobee NodeServer Version 2.0.11 and then at 2018-12-22 15:58:20,298 [Interface ] [INFO ] MQTT Unexpected disconnection. Trying reconnect. and then it kept getting that over and over, and in the polyglot log I see at that same time 2018-12-22 15:58:08 - info: Ecobee(12): Attempting to install Ecobee NodeServer into ISY. So based on this, my guess is that there were actually 2 copies of the Ecobee nodeserver running on that machine. I've only seen this happen when running polyglot manually from a checkout of the repo. Can you make sure there are not two running: ps -ef | grep ecobee and you should only see one python3 ./ecobee-poly.py Link to comment Share on other sites More sharing options...
markv58 Posted December 23, 2018 Share Posted December 23, 2018 32 minutes ago, Jimbo said: Can you make sure there are not two running: ps -ef | grep ecobee and you should only see one python3 ./ecobee-poly.py Only one running. When I installed the older version in slot 12 I neglected to stop the other version so there was a lot of disconnect error stuff. I just switched back over to 2.0.11 and watched the log and noticed that the drivers are not updated in polyglot when the long poll completes. I also did a git pull and captured your last changes. 2.0.11 2.0.5 Link to comment Share on other sites More sharing options...
starmanj Posted December 23, 2018 Share Posted December 23, 2018 FYI, Cloud says latest version is 2.011, but stopping and starting service still yields 2.010... Do I need to delete and re-install? Link to comment Share on other sites More sharing options...
Foebik Posted December 23, 2018 Share Posted December 23, 2018 While on the topic of versions, why do the logs say this:Ecobee NodeServer Version 2.0.11a But the Title page stills says:Current Version: 2.0.11 Minus the "a" Also, I forget the exact version, but for the longest time, the title page was way off, reading something like 2.0.2. Even when the logs read something much higher. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted December 23, 2018 Author Share Posted December 23, 2018 1 hour ago, markv58 said: Only one running. When I installed the older version in slot 12 I neglected to stop the other version so there was a lot of disconnect error stuff. I just switched back over to 2.0.11 and watched the log and noticed that the drivers are not updated in polyglot when the long poll completes. I also did a git pull and captured your last changes. Yes, just found the bug causing updates to not come thru on long poll, it happened when I added the 't' prefix to thermostat node address. Hopefully can release all my fixes later tonight. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted December 23, 2018 Author Share Posted December 23, 2018 17 minutes ago, starmanj said: FYI, Cloud says latest version is 2.011, but stopping and starting service still yields 2.010... Do I need to delete and re-install? No, that's a bug in Polyglot Cloud that should get fixed soon. You can see in log the version number. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted December 23, 2018 Author Share Posted December 23, 2018 11 minutes ago, Foebik said: While on the topic of versions, why do the logs say this:Ecobee NodeServer Version 2.0.11a But the Title page stills says:Current Version: 2.0.11 Minus the "a" Also, I forget the exact version, but for the longest time, the title page was way off, reading something like 2.0.2. Even when the logs read something much higher. Currently we can only debug Polyglot Could with master of the github, so I added that a just to see that it was actually updating. Yes, same answer as post above about the version. Link to comment Share on other sites More sharing options...
carealtor Posted December 24, 2018 Share Posted December 24, 2018 I'm still showing only one of my two thermostats and the data is all blank. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted December 24, 2018 Author Share Posted December 24, 2018 Version 2.0.12 is released: https://github.com/Einstein42/udi-ecobee-poly#release-notes It should be in the store within the hour. I've tested both local and cloud, everything looks good except some drivers are not initializing properly on cloud but it doesn't cause any problem. Give it a try and let me know if you have any issues. Link to comment Share on other sites More sharing options...
TexMike Posted December 24, 2018 Share Posted December 24, 2018 Getting updates now, looking good so far. Thanks, Mike Link to comment Share on other sites More sharing options...
carealtor Posted December 24, 2018 Share Posted December 24, 2018 I'm seeing data now too... but still only one of my two thermostats. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted December 24, 2018 Author Share Posted December 24, 2018 I'm seeing data now too... but still only one of my two thermostats. Should not be an issue but I don't have 2 to test with. Are you running local or cloud? If local please PM me the log package, if cloud please copy and paste as much of the log as you can. I'll try to look tomorrow.Sent from my Pixel 3 XL using Tapatalk Link to comment Share on other sites More sharing options...
carealtor Posted December 24, 2018 Share Posted December 24, 2018 Thanks Jimbo. I'm using Cloud. 12/23/18 21:07:28:357 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:49:35:722 [MainThread][INFO ] :: PGC Interface 1.0.11 Starting... 12/23/18 20:49:35:918 [Interface ][INFO ] :: Adding node Ecobee Controller(controller) 12/23/18 20:49:38:220 [NodeServer][INFO ] :: check_profile: update_profile=True 12/23/18 20:49:38:124 [NodeServer][INFO ] :: Sending Install Profile command to Polyglot. 12/23/18 20:49:37:818 [Interface ][DEBUG] :: Received Message: {'result': {'addnode': {'success': True, 'address': 'controller'}}} 12/23/18 20:49:37:935 [NodeServer][INFO ] :: Ecobee NodeServer Version 2.0.12a 12/23/18 20:49:37:829 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:49:35:834 [Interface ][DEBUG] :: Recieved Message: init 12/23/18 20:49:38:013 [NodeServer][INFO ] :: Sending notices to Polyglot. 12/23/18 20:49:38:113 [NodeServer][INFO ] :: check_profile: profile_info={'version': '2.0.7'} customData={} 12/23/18 20:49:37:918 [NodeServer][INFO ] :: Started Ecobee v2 NodeServer 12/23/18 20:49:38:924 [NodeServer][DEBUG] :: {'ecobeePin': '3656', 'code': 'SYzSKHXVyU9qEI39iMDpTbmDPvsG6olT', 'scope': 'smartWrite', 'expires_in': 9, 'interval': 30} 12/23/18 20:49:35:918 [Interface ][INFO ] :: Waiting on Controller node to be added....... 12/23/18 20:49:38:417 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:49:38:226 [NodeServer][INFO ] :: Sending customData to Polyglot. 12/23/18 20:49:38:318 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:49:39:218 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:49:38:935 [NodeServer][INFO ] :: Sending notices to Polyglot. 12/23/18 20:50:39:734 [NodeServer][DEBUG] :: {'access_token': 'iV314Q2wSgDMQRyp2CFBRZY0qr3bOjmT', 'token_type': 'Bearer', 'expires_in': 3599, 'refresh_token': 'paYx4UFp2zoAcoyGW9PNoW8w364Vo2f5', 'scope': 'smartWrite'} 12/23/18 20:50:42:143 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:50:31:518 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:50:40:435 [NodeServer][INFO ] :: Getting Full Thermostat Data for 311039562871 12/23/18 20:50:40:023 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:50:41:738 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:50:39:819 [NodeServer][INFO ] :: Sending customData to Polyglot. 12/23/18 20:50:39:819 [NodeServer][INFO ] :: Sending notices to Polyglot. 12/23/18 20:50:40:930 [NodeServer][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 20:50:42:725 [Controller][INFO ] :: Adding node Ecobee - Master Bedroom(rs_xr8x) 12/23/18 20:50:41:429 [NodeServer][INFO ] :: Adding node Ecobee - Main Living \ Office(t311016154806) 12/23/18 20:50:40:424 [NodeServer][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 20:50:39:819 [NodeServer][INFO ] :: Discovering Ecobee Thermostats 12/23/18 20:50:39:925 [NodeServer][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 20:50:40:017 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:50:40:936 [NodeServer][INFO ] :: Getting Full Thermostat Data for 311016154806 12/23/18 20:50:42:728 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:50:42:815 [Controller][ERROR] :: reportDriver: 'GV9' 12/23/18 20:50:42:813 [Controller][ERROR] :: reportDriver: 'GV3' 12/23/18 20:50:42:726 [Controller][INFO ] :: Updating Driver t311039562871 - CLISPH: 67 uom: 17 12/23/18 20:50:42:817 [Controller][ERROR] :: reportDriver: 'GV9' 12/23/18 20:50:42:726 [Controller][INFO ] :: Updating Driver t311039562871 - GV1: 36 uom: 22 12/23/18 20:50:42:814 [Controller][ERROR] :: reportDriver: 'GV8' 12/23/18 20:50:42:726 [Controller][INFO ] :: Updating Driver t311039562871 - GV3: 1 uom: 25 12/23/18 20:50:42:727 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:50:42:815 [Controller][ERROR] :: reportDriver: 'GV2' 12/23/18 20:50:43:825 [Controller][ERROR] :: reportDriver: 'GV4' 12/23/18 20:50:42:725 [Controller][INFO ] :: Updating Driver t311039562871 - ST: 67 uom: 17 12/23/18 20:50:42:816 [Controller][ERROR] :: reportDriver: 'GV7' 12/23/18 20:50:43:819 [Controller][INFO ] :: Adding node Ecobee - Forecast(f311016154806) 12/23/18 20:50:42:725 [Controller][INFO ] :: Adding node Ecobee - Weather(w311039562871) 12/23/18 20:50:43:820 [Controller][INFO ] :: Updating Driver t311016154806 - ST: 69 uom: 17 12/23/18 20:50:42:729 [Controller][ERROR] :: reportDriver: 'GV2' 12/23/18 20:50:39:113 [NodeServer][DEBUG] :: PIN: 3656 found. Attempting to get tokens... 12/23/18 20:50:43:822 [Controller][ERROR] :: reportDriver: 'GV2' 12/23/18 20:50:43:819 [Controller][INFO ] :: Adding node Ecobee - Family Room(rs_x3rf) 12/23/18 20:50:43:824 [Controller][ERROR] :: reportDriver: 'GV8' 12/23/18 20:50:42:726 [Controller][INFO ] :: Updating Driver t311039562871 - CLIMD: 1 uom: 67 12/23/18 20:50:42:816 [Controller][ERROR] :: reportDriver: 'GV5' 12/23/18 20:50:43:826 [Controller][ERROR] :: reportDriver: 'GV6' 12/23/18 20:50:42:817 [Controller][ERROR] :: reportDriver: 'GV8' 12/23/18 20:50:42:725 [Controller][INFO ] :: Adding node Ecobee - Bedrooms(s311039562871) 12/23/18 20:50:43:825 [Controller][ERROR] :: reportDriver: 'GV3' 12/23/18 20:50:43:406 [Interface ][DEBUG] :: Received Message: {'result': {'addnode': {'success': True, 'address': 's311039562871'}}} 12/23/18 20:50:43:823 [Controller][ERROR] :: reportDriver: 'GV4' 12/23/18 20:50:43:825 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:50:42:814 [Controller][ERROR] :: reportDriver: 'GV7' 12/23/18 20:50:43:824 [Controller][ERROR] :: reportDriver: 'GV7' 12/23/18 20:50:43:826 [Controller][ERROR] :: reportDriver: 'GV8' 12/23/18 20:50:43:820 [Controller][INFO ] :: Updating Driver t311016154806 - CLISPH: 68 uom: 17 12/23/18 20:50:43:873 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:50:43:822 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:50:41:722 [Interface ][DEBUG] :: Received Message: {'result': {'addnode': {'success': True, 'address': 't311039562871'}}} 12/23/18 20:50:44:071 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:52:27:429 [Controller][DEBUG] :: controller:longPoll 12/23/18 20:50:44:296 [Interface ][DEBUG] :: Received Message: {'result': {'addnode': {'success': True, 'address': 'w311039562871'}}} 12/23/18 20:51:27:418 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 20:52:27:606 [Controller][INFO ] :: No 311016154806 'Main Living \ Office' update detected 12/23/18 20:50:40:914 [NodeServer][INFO ] :: Adding node Ecobee - Bedrooms(t311039562871) 12/23/18 20:55:27:897 [Controller][INFO ] :: Updating Driver w311039562871 - GV3: 53.6 uom: 17 12/23/18 20:50:43:821 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:50:42:815 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:50:42:813 [Controller][ERROR] :: reportDriver: 'GV4' 12/23/18 20:50:43:818 [Controller][DEBUG] :: caught fnode fail due to polyglot bug? assuming old node not found 12/23/18 20:50:44:315 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:27:514 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 20:50:43:821 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:55:27:678 [Controller][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 20:50:43:822 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:55:27:429 [Controller][DEBUG] :: controller:longPoll 12/23/18 20:50:43:822 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:50:42:725 [Controller][DEBUG] :: caught fnode fail due to polyglot bug? assuming old node not found 12/23/18 20:50:43:826 [Controller][ERROR] :: reportDriver: 'GV5' 12/23/18 20:50:43:819 [Controller][DEBUG] :: caught fnode fail due to polyglot bug? assuming old node not found 12/23/18 20:50:42:727 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:52:27:430 [Controller][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 20:52:27:429 [Controller][DEBUG] :: controller:updateThermostats: 12/23/18 20:50:42:725 [Controller][INFO ] :: Adding node Ecobee - Forecast(f311039562871) 12/23/18 20:50:46:896 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:27:678 [Controller][INFO ] :: Getting Full Thermostat Data for 311039562871 12/23/18 20:50:43:824 [Controller][ERROR] :: reportDriver: 'GV9' 12/23/18 20:50:42:814 [Controller][ERROR] :: reportDriver: 'GV5' 12/23/18 20:50:43:823 [Controller][ERROR] :: reportDriver: 'GV5' 12/23/18 20:50:45:260 [Interface ][DEBUG] :: Received Message: {'result': {'addnode': {'success': True, 'address': 'f311039562871'}}} 12/23/18 20:54:27:518 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 20:50:43:820 [Controller][INFO ] :: Updating Driver t311016154806 - GV3: 1 uom: 25 12/23/18 20:50:43:423 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:50:43:826 [Controller][ERROR] :: reportDriver: 'GV7' 12/23/18 20:55:27:678 [Controller][DEBUG] :: Update detected in thermostat Bedrooms(t311039562871) doing full update. 12/23/18 20:55:27:897 [Controller][INFO ] :: Updating Driver w311039562871 - GV1: 92 uom: 22 12/23/18 20:55:27:897 [Controller][INFO ] :: Updating Driver w311039562871 - ST: 47.3 uom: 17 12/23/18 20:50:42:726 [Controller][INFO ] :: Updating Driver t311039562871 - CLISPC: 79 uom: 17 12/23/18 20:50:42:815 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:50:43:820 [Controller][INFO ] :: Updating Driver t311016154806 - CLIMD: 1 uom: 67 12/23/18 20:55:27:896 [Controller][INFO ] :: Updating Driver rs_xr8x - ST: 67.6 uom: 17 12/23/18 20:50:43:758 [Interface ][DEBUG] :: Received Message: {'result': {'addnode': {'success': True, 'address': 'rs_xr8x'}}} 12/23/18 20:50:46:879 [Interface ][DEBUG] :: Received Message: {'result': {'addnode': {'success': True, 'address': 's311016154806'}}} 12/23/18 20:50:43:743 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:50:39:818 [NodeServer][DEBUG] :: Got first set of tokens sucessfully. 12/23/18 20:50:43:820 [Controller][INFO ] :: Updating Driver t311016154806 - GV1: 36 uom: 22 12/23/18 20:50:42:728 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:52:27:429 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 20:50:42:814 [Controller][ERROR] :: reportDriver: 'GV6' 12/23/18 20:50:43:824 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:50:43:827 [Controller][ERROR] :: reportDriver: 'GV9' 12/23/18 20:52:27:418 [Interface ][DEBUG] :: Received Message: {'longPoll': {}} 12/23/18 20:50:45:047 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:50:27:418 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 20:50:42:728 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:50:42:728 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:50:42:816 [Controller][ERROR] :: reportDriver: 'GV3' 12/23/18 20:50:44:857 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:50:42:726 [Controller][INFO ] :: Updating Driver t311039562871 - GV5: 60 uom: 22 12/23/18 20:50:44:971 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:52:27:606 [Controller][INFO ] :: No 311039562871 'Bedrooms' update detected 12/23/18 20:55:27:418 [Interface ][DEBUG] :: Received Message: {'longPoll': {}} 12/23/18 20:50:45:389 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:50:42:726 [Controller][INFO ] :: Updating Driver t311039562871 - CLIHUM: 52 uom: 22 12/23/18 20:50:42:130 [Interface ][DEBUG] :: Received Message: {'result': {'addnode': {'success': True, 'address': 't311016154806'}}} 12/23/18 20:50:43:813 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:50:43:823 [Controller][ERROR] :: reportDriver: 'GV6' 12/23/18 20:50:43:819 [Controller][INFO ] :: Adding node Ecobee - Weather(w311016154806) 12/23/18 20:55:27:429 [Controller][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 20:50:42:816 [Controller][ERROR] :: reportDriver: 'GV6' 12/23/18 20:50:43:819 [Controller][INFO ] :: Adding node Ecobee - Main Living \ Office(s311016154806) 12/23/18 20:50:43:821 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:55:27:897 [Controller][INFO ] :: Updating Driver s311039562871 - ST: 67.7 uom: 17 12/23/18 20:50:42:724 [Controller][DEBUG] :: caught fnode fail due to polyglot bug? assuming old node not found 12/23/18 20:50:43:823 [Controller][ERROR] :: reportDriver: 'GV3' 12/23/18 20:50:43:825 [Controller][ERROR] :: reportDriver: 'GV2' 12/23/18 20:50:43:820 [Controller][INFO ] :: Updating Driver t311016154806 - CLIHUM: 48 uom: 22 12/23/18 20:50:42:816 [Controller][ERROR] :: reportDriver: 'GV4' 12/23/18 20:50:43:975 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:27:898 [Controller][INFO ] :: Updating Driver w311039562871 - GV7: 5 uom: 25 12/23/18 20:50:43:820 [Controller][INFO ] :: Updating Driver t311016154806 - CLISPC: 78 uom: 17 12/23/18 20:55:27:897 [Controller][INFO ] :: Updating Driver w311039562871 - GV5: 6 uom: 48 12/23/18 20:53:27:418 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 20:55:27:897 [Controller][INFO ] :: Updating Driver w311039562871 - GV4: 44.6 uom: 17 12/23/18 20:55:27:897 [Controller][INFO ] :: Updating Driver w311039562871 - GV6: 1 uom: 25 12/23/18 20:50:43:820 [Controller][INFO ] :: Updating Driver t311016154806 - GV5: 60 uom: 22 12/23/18 20:50:45:278 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:27:898 [Controller][INFO ] :: Updating Driver f311039562871 - ST: 48.5 uom: 17 12/23/18 20:55:27:898 [Controller][INFO ] :: Updating Driver w311039562871 - GV9: 3 uom: 25 12/23/18 20:55:27:899 [Controller][INFO ] :: Updating Driver f311039562871 - GV4: 42.9 uom: 17 12/23/18 20:55:27:899 [Controller][INFO ] :: Updating Driver f311039562871 - GV9: 6 uom: 25 12/23/18 20:55:27:900 [Controller][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 20:55:27:898 [Controller][INFO ] :: Updating Driver f311039562871 - GV2: 81 uom: 22 12/23/18 20:55:27:898 [Controller][INFO ] :: Updating Driver f311039562871 - GV1: 89 uom: 22 12/23/18 20:55:27:899 [Controller][INFO ] :: Updating Driver f311039562871 - GV5: 6 uom: 48 12/23/18 20:55:27:899 [Controller][DEBUG] :: Update detected in thermostat Main Living \ Office(t311016154806) doing full update. 12/23/18 20:55:28:545 [Controller][INFO ] :: Updating Driver t311016154806 - ST: 69 uom: 17 12/23/18 20:55:27:899 [Controller][INFO ] :: Updating Driver f311039562871 - GV3: 54.2 uom: 17 12/23/18 20:55:28:545 [Controller][INFO ] :: Updating Driver t311016154806 - CLISPC: 78 uom: 17 12/23/18 20:55:28:546 [Controller][INFO ] :: Updating Driver t311016154806 - CLIHUM: 49 uom: 22 12/23/18 20:55:28:546 [Controller][INFO ] :: Updating Driver t311016154806 - GV5: 60 uom: 22 12/23/18 20:55:27:900 [Controller][INFO ] :: Getting Full Thermostat Data for 311016154806 12/23/18 20:55:27:899 [Controller][INFO ] :: Updating Driver f311039562871 - GV6: 8 uom: 25 12/23/18 20:55:28:547 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:55:27:429 [Controller][DEBUG] :: controller:updateThermostats: 12/23/18 20:55:28:545 [Controller][INFO ] :: Updating Driver t311016154806 - CLIMD: 1 uom: 67 12/23/18 20:55:27:898 [Controller][INFO ] :: Updating Driver w311039562871 - GV8: 3 uom: 25 12/23/18 20:55:28:546 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:55:28:547 [Controller][INFO ] :: Updating Driver s311016154806 - ST: 69.2 uom: 17 12/23/18 20:55:28:546 [Controller][INFO ] :: Updating Driver t311016154806 - GV1: 36 uom: 22 12/23/18 20:55:28:547 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:55:28:548 [Controller][ERROR] :: reportDriver: 'GV3' 12/23/18 20:55:28:614 [Controller][ERROR] :: reportDriver: 'GV2' 12/23/18 20:55:28:615 [Controller][ERROR] :: reportDriver: 'GV4' 12/23/18 20:55:28:615 [Controller][ERROR] :: reportDriver: 'GV7' 12/23/18 20:55:29:718 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:28:622 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:28:613 [Controller][ERROR] :: reportDriver: 'GV9' 12/23/18 20:55:28:549 [Controller][ERROR] :: reportDriver: 'GV7' 12/23/18 20:58:28:021 [Controller][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 20:55:28:615 [Controller][ERROR] :: reportDriver: 'GV6' 12/23/18 20:58:27:518 [Interface ][DEBUG] :: Received Message: {'longPoll': {}} 12/23/18 20:55:28:548 [Controller][ERROR] :: reportDriver: 'GV5' 12/23/18 20:55:28:616 [Controller][ERROR] :: reportDriver: 'GV8' 12/23/18 20:55:28:919 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:29:931 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:28:615 [Controller][ERROR] :: reportDriver: 'GV5' 12/23/18 20:55:29:625 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:58:27:614 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 20:55:28:548 [Controller][ERROR] :: reportDriver: 'GV6' 12/23/18 20:55:28:819 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:29:419 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:28:918 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:30:118 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:58:27:524 [Controller][DEBUG] :: controller:longPoll 12/23/18 20:55:30:536 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:29:619 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:28:548 [Controller][ERROR] :: reportDriver: 'GV4' 12/23/18 20:55:28:614 [Controller][ERROR] :: reportDriver: 'GV3' 12/23/18 20:55:29:218 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:30:519 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:57:27:618 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 20:58:28:021 [Controller][DEBUG] :: Update detected in thermostat Bedrooms(t311039562871) doing full update. 12/23/18 20:55:29:918 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:30:218 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:28:614 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:55:28:546 [Controller][INFO ] :: Updating Driver t311016154806 - GV3: 1 uom: 25 12/23/18 20:56:27:524 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 20:55:30:319 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:28:613 [Controller][ERROR] :: reportDriver: 'GV8' 12/23/18 20:55:30:818 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:28:616 [Controller][ERROR] :: reportDriver: 'GV9' 12/23/18 20:58:27:524 [Controller][DEBUG] :: controller:updateThermostats: 12/23/18 20:55:28:614 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:55:27:899 [Controller][INFO ] :: Updating Driver f311039562871 - GV8: 6 uom: 25 12/23/18 20:55:27:899 [Controller][INFO ] :: Updating Driver f311039562871 - GV7: 4 uom: 25 12/23/18 20:58:27:524 [Controller][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 20:55:28:547 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:55:30:919 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:28:547 [Controller][ERROR] :: reportDriver: 'GV2' 12/23/18 20:55:29:225 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:30:718 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:29:118 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 20:55:28:545 [Controller][INFO ] :: Updating Driver t311016154806 - CLISPH: 68 uom: 17 12/23/18 20:58:28:410 [Controller][DEBUG] :: Update detected in thermostat Main Living \ Office(t311016154806) doing full update. 12/23/18 20:58:28:022 [Controller][INFO ] :: Getting Full Thermostat Data for 311039562871 12/23/18 20:58:28:411 [Controller][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 20:58:28:630 [Controller][INFO ] :: Updating Driver t311016154806 - CLISPH: 68 uom: 17 12/23/18 20:58:28:630 [Controller][INFO ] :: Updating Driver t311016154806 - ST: 69 uom: 17 12/23/18 20:58:28:411 [Controller][INFO ] :: Getting Full Thermostat Data for 311016154806 12/23/18 20:58:28:630 [Controller][INFO ] :: Updating Driver t311016154806 - CLISPC: 78 uom: 17 12/23/18 20:58:28:630 [Controller][INFO ] :: Updating Driver t311016154806 - CLIHUM: 49 uom: 22 12/23/18 20:58:28:630 [Controller][INFO ] :: Updating Driver t311016154806 - CLIMD: 1 uom: 67 12/23/18 20:58:28:630 [Controller][INFO ] :: Updating Driver t311016154806 - GV1: 36 uom: 22 12/23/18 20:58:28:630 [Controller][INFO ] :: Updating Driver t311016154806 - GV3: 1 uom: 25 12/23/18 20:58:28:631 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:58:28:632 [Controller][ERROR] :: reportDriver: 'GV2' 12/23/18 20:58:28:631 [Controller][INFO ] :: Updating Driver t311016154806 - GV5: 60 uom: 22 12/23/18 20:58:28:715 [Controller][ERROR] :: reportDriver: 'GV3' 12/23/18 21:01:27:699 [Controller][INFO ] :: Getting Full Thermostat Data for 311039562871 12/23/18 20:58:28:715 [Controller][ERROR] :: reportDriver: 'GV4' 12/23/18 20:58:28:632 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:58:28:714 [Controller][ERROR] :: reportDriver: 'GV7' 12/23/18 20:58:28:714 [Controller][ERROR] :: reportDriver: 'GV9' 12/23/18 20:58:28:715 [Controller][ERROR] :: reportDriver: 'GV2' 12/23/18 20:58:28:716 [Controller][ERROR] :: reportDriver: 'GV7' 12/23/18 20:58:28:631 [Controller][INFO ] :: Updating Driver s311016154806 - ST: 69.2 uom: 17 12/23/18 20:58:28:716 [Controller][ERROR] :: reportDriver: 'GV5' 12/23/18 20:58:28:716 [Controller][ERROR] :: reportDriver: 'GV6' 12/23/18 20:59:27:718 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 21:01:28:233 [Controller][INFO ] :: Updating Driver t311016154806 - CLISPC: 85 uom: 17 12/23/18 21:00:27:718 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 21:01:27:933 [Controller][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 21:01:28:313 [Controller][INFO ] :: Updating Driver t311016154806 - GV3: 2 uom: 25 12/23/18 21:01:28:233 [Controller][INFO ] :: Updating Driver t311016154806 - CLIMD: 1 uom: 67 12/23/18 21:01:28:233 [Controller][INFO ] :: Updating Driver t311016154806 - CLISPH: 58 uom: 17 12/23/18 20:58:28:715 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 21:01:28:317 [Controller][ERROR] :: reportDriver: 'GV9' 12/23/18 20:58:28:713 [Controller][ERROR] :: reportDriver: 'GV6' 12/23/18 20:58:28:632 [Controller][ERROR] :: reportDriver: 'GV3' 12/23/18 21:01:28:313 [Controller][INFO ] :: Updating Driver t311016154806 - GV1: 36 uom: 22 12/23/18 21:01:28:314 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 21:01:27:524 [Controller][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 20:58:28:633 [Controller][ERROR] :: reportDriver: 'GV4' 12/23/18 20:58:28:715 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 21:01:28:316 [Controller][ERROR] :: reportDriver: 'GV7' 12/23/18 21:01:28:316 [Controller][ERROR] :: reportDriver: 'GV4' 12/23/18 21:01:28:316 [Controller][ERROR] :: reportDriver: 'GV5' 12/23/18 20:58:28:713 [Controller][ERROR] :: reportDriver: 'GV5' 12/23/18 21:01:27:524 [Controller][DEBUG] :: controller:updateThermostats: 12/23/18 20:58:28:717 [Controller][ERROR] :: reportDriver: 'GV9' 12/23/18 21:01:27:518 [Interface ][DEBUG] :: Received Message: {'longPoll': {}} 12/23/18 21:01:28:314 [Controller][INFO ] :: Updating Driver s311016154806 - ST: 69.3 uom: 17 12/23/18 21:01:27:524 [Controller][DEBUG] :: controller:longPoll 12/23/18 21:01:28:316 [Controller][ERROR] :: reportDriver: 'GV6' 12/23/18 21:01:27:934 [Controller][INFO ] :: Getting Full Thermostat Data for 311016154806 12/23/18 21:01:28:315 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 20:58:28:717 [Controller][ERROR] :: reportDriver: 'GV8' 12/23/18 21:01:28:315 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:58:28:714 [Controller][ERROR] :: reportDriver: 'GV8' 12/23/18 21:01:27:699 [Controller][DEBUG] :: Update detected in thermostat Bedrooms(t311039562871) doing full update. 12/23/18 21:01:28:314 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 21:01:28:316 [Controller][ERROR] :: reportDriver: 'GV8' 12/23/18 21:01:28:232 [Controller][INFO ] :: Updating Driver t311016154806 - ST: 69 uom: 17 12/23/18 21:01:28:317 [Controller][ERROR] :: reportDriver: 'GV2' 12/23/18 20:58:28:631 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 20:58:28:632 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 21:01:28:317 [Controller][ERROR] :: reportDriver: 'ST' 12/23/18 21:01:28:315 [Controller][ERROR] :: reportDriver: 'GV3' 12/23/18 21:01:28:315 [Controller][ERROR] :: reportDriver: 'GV2' 12/23/18 21:01:27:699 [Controller][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 21:03:24:218 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 21:01:27:714 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 21:01:28:313 [Controller][INFO ] :: Updating Driver t311016154806 - CLIHUM: 49 uom: 22 12/23/18 21:01:28:314 [Controller][INFO ] :: Updating Driver t311016154806 - GV5: 60 uom: 22 12/23/18 21:01:27:933 [Controller][DEBUG] :: Update detected in thermostat Main Living \ Office(t311016154806) doing full update. 12/23/18 21:01:28:317 [Controller][ERROR] :: reportDriver: 'GV1' 12/23/18 21:03:32:419 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 21:03:32:425 [Interface ][DEBUG] :: Recieved Message: config 12/23/18 21:16:28:008 [Controller][DEBUG] :: Update detected in thermostat Bedrooms(t311039562871) doing full update. 12/23/18 21:14:28:318 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 21:16:27:824 [Controller][DEBUG] :: controller:updateThermostats: 12/23/18 21:15:28:418 [Interface ][DEBUG] :: Received Message: {'shortPoll': {}} 12/23/18 21:16:27:824 [Controller][DEBUG] :: controller:longPoll 12/23/18 21:16:28:008 [Controller][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 12/23/18 21:16:27:818 [Interface ][DEBUG] :: Received Message: {'longPoll': {}} 12/23/18 21:16:27:824 [Controller][DEBUG] :: Tokens valid until: 2018-12-24T05:50:38 Link to comment Share on other sites More sharing options...
TexMike Posted December 24, 2018 Share Posted December 24, 2018 Both of mine appear to be working from cloud. Link to comment Share on other sites More sharing options...
RocKKer Posted December 24, 2018 Share Posted December 24, 2018 I tried 2.0.02 (obviously it had problems) then when 2.0.10 came out I stopped it and tried to start it (because it was supposed to update by starting it, but it didn't), I deleted and installed 10.0.10 when it came out, deleted that because again the auto update didn't work, deleted that and now I'm trying to install 2.0.12 which gives me a bunch of red error box (generally not immediately), I get several different messages: some are: "No worker available to be assigned" "Couldn't update Driver to ISY status 404" "ISYGetNodeServers Response wasn't XML" A couple socket errors that I haven't been able to capture yet....Also rebooted the ISY a couple times. On polyglot.io, it only shows: ISY Portal(2) Current Status: Unmanaged "no details available" ISY-994i is at 5.0.14 If you don't get around to this until after tomorrow that is more than ok, I am not in any hurry. Link to comment Share on other sites More sharing options...
yvg240 Posted December 24, 2018 Share Posted December 24, 2018 I'm running 2.0.12 now on my local Polyglot and can see all three of my t-stats. All of the data and the details seem to be correct. However I cannot make any changes to them like adjusting set points, mode and such. Is this expected behavior or should I be able to make changes to the t-stats? Thanks in advance! Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted December 24, 2018 Author Share Posted December 24, 2018 I tried 2.0.02 (obviously it had problems) then when 2.0.10 came out I stopped it and tried to start it (because it was supposed to update by starting it, but it didn't), I deleted and installed 10.0.10 when it came out, deleted that because again the auto update didn't work, deleted that and now I'm trying to install 2.0.12 which gives me a bunch of red error box (generally not immediately), I get several different messages: some are: "No worker available to be assigned" "Couldn't update Driver to ISY status 404" "ISYGetNodeServers Response wasn't XML" A couple socket errors that I haven't been able to capture yet....Also rebooted the ISY a couple times. On polyglot.io, it only shows: ISY Portal(2) Current Status: Unmanaged "no details available" ISY-994i is at 5.0.14 If you don't get around to this until after tomorrow that is more than ok, I am not in any hurry. Those are all Polyglot issues. You don't need to delete and restart, even though when you stop and start it shows it's running the old it's actually not. You can see the version in the log.Sent from my Pixel 3 XL using Tapatalk Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted December 24, 2018 Author Share Posted December 24, 2018 I'm running 2.0.12 now on my local Polyglot and can see all three of my t-stats. All of the data and the details seem to be correct. However I cannot make any changes to them like adjusting set points, mode and such. Is this expected behavior or should I be able to make changes to the t-stats? Thanks in advance! You should be able to make changes, send me the log package and I'll look when I get time.Sent from my Pixel 3 XL using Tapatalk Link to comment Share on other sites More sharing options...
carealtor Posted December 24, 2018 Share Posted December 24, 2018 34 minutes ago, RocKKer said: "Couldn't update Driver to ISY status 404" "ISYGetNodeServers Response wasn't XML" I get a lot of those too. Link to comment Share on other sites More sharing options...
yvg240 Posted December 24, 2018 Share Posted December 24, 2018 1 hour ago, Jimbo said: You should be able to make changes, send me the log package and I'll look when I get time. Sent from my Pixel 3 XL using Tapatalk Thanks. I just messaged the logs to you. No rush, enjoy your holiday! Link to comment Share on other sites More sharing options...
Foebik Posted December 26, 2018 Share Posted December 26, 2018 So something I noticed just recently. The Occupancy variable does change for the the satellite sensors, but not for the thermostats itself. Link to comment Share on other sites More sharing options...
carealtor Posted December 26, 2018 Share Posted December 26, 2018 I'm seeing the same thing as @Foebik The Occupancy changes for the remote sensor, but is always No for the thermostat sensor. Link to comment Share on other sites More sharing options...
