Problem with door status not showing correctly
Blackbird
For some reason the Agave app is showing the status of doors incorrectly.  Mobilinc is accurate but not Agave.  For example, I load Agave and see that my patio door is showing open even though its closed.  I open the door then close it then the status shows closed.  Anyone else having this problem?
What are you using as your sensor? Do you have ‘trigger reverse’ set? What about after a query?
Insteon door sensors.  No trigger reverse.  Not sure about the query.  Did a refresh data on agave.  Just checked and my Patio door is showing open again and I haven't touched it as well as a few of my other doors which are actually closed.
Reseting the data worked then a couple hours later I see that all my wireless sensors are reversed.  All doors show open and the leak sensors only show "dry" with a status of dry.  No "wet" sensors
The home screen shows some doors closed.  Then when I look in the Sensor/security section is says open the I go back to the home screen and that says open.  What is wrong with this app?
When a sensor shows reversed in Agave, what does it show in UDAjax (or the Admin Console)?
I believe that Agave is only reporting what the ISY is telling it. Unless ISY is sending it data that’s not being parsed correctly. In this case, get the xml response from a REST query of the device and send it to the author so he can look into it.
I am showing 5 screen shots labeled 1 through 5.  This is the sequence I used when loading up Agave a few minutes ago.  See how the first home page is correct then by going to sensors/security, it changes the status.
More problems.  I sent the debug report.  The previous problem of the steps shown in the previous post seem to still be corrected.  The problem I have now (maybe all along) is when im on the home screen and I tap on the icon in the top left of the device (only noticed this for doors) it takes me to the option screen as it should and the device reads closed which is correct but when I go back to the home screen, it changes the status to OPEN which is incorrect.  I can make it do this every single time for all my doors.  Simply refreshing the data doesn't always correct it, sometimes I have to refresh data and clear app cache then reload Agave and the status's are all correct.  I have one door that is physically open so when I click on the icon in the upper left corner for that door, I would expect the status to show incorrectly as closed but it doesn't, it remains open.
  • 1 month later...
I have one 2843-222 door sensor that when closed, shows its status correctly on the ISY, but wrongly on Agave. The 'reverse status' is not checked. If I cycle it, Agave reads correctly for a time, but when refreshed reverts to 'open' when the door is closed. It reads correctly when the door is open, even after refreshed.
I also have 3 2845-222s that work correctly. All 4 of them show up as the same <type>16.17.69.0</type> in a node dump.
I would appreciate help on this. Thanks,
Expand
What mode are your devices in?
  On 2/5/2019 at 2:50 PM, oetbyg said:
That is the case for me. 3 hidden door sensors (2845-222) work OK, the Open/Close sensor (2843-222) does not.
Expand
The two types show identical behavior in the UD console event viewer if that's any help:
2843-222:
Tue 02/05/2019 10:07:13 : [  3B 3F 83 1]      DON   1
Tue 02/05/2019 10:07:13 : [  3B 3F 83 1]       ST 255 (uom=100 prec=0)
Tue 02/05/2019 10:07:16 : [  3B 3F 83 1]      DOF   1
Tue 02/05/2019 10:07:16 : [  3B 3F 83 1]       ST   0 (uom=100 prec=0)
2845-222:
Tue 02/05/2019 10:02:53 : [  2D EF 2F 1]      DON   1
Tue 02/05/2019 10:02:53 : [  2D EF 2F 1]       ST 255 (uom=100 prec=0)
Tue 02/05/2019 10:02:56 : [  2D EF 2F 1]      DOF   1
Tue 02/05/2019 10:02:56 : [  2D EF 2F 1]       ST   0 (uom=100 prec=0)
