Anyone running nodelink on synology in docker?
You said replace. Do you mean add? There is no hostname section in that file:
Once configured by the web interface it will have a section like this:
(With correct value)
I guess try adding that manually.
After a bit of searching, I found another config.xml file posted with an "isy admin" section with the IP address, login, password etc.
I added the section with just the address:
  <section name="isy admin">
    <item key="address" value="192.168.1.52" />
  </section>
...and now the container starts and doesn't crash :)
Did you try to post an image or something? Something seems to be missing from the post?
I'm now able to reach the web config server.
It seems this really is a bit of check or egg problem. It seems like nodelink shouldn't try to parse the hostname if there isn't an "isy admin" section in the first place.
Wasn’t an image, but something about XML? formatting that is not showing up through Tapatalk on my phone (shows up fine when using my PC browser). I couldn’t see the details of your config file post until I quoted it for reply. Glad to hear you found another example.
Try 0.9.26.
It should allow you to edit this in the web config.
