Current Backlight level
5 minutes ago, gzahar said:
What I am saying is that you don't need to set the level twice on the second device.  Just hit the backlight button (without changing the dropdown) and it should write the current value in the dropdown (what you set the first device to) to the second device.
I just tried this, your correct!!    This is an update in later 5.x I believe, I just tried looking thru release notes but didn't immediately spot a line I'm remembering about the buttons.
I'm on 5.0.16C and it has been that way as long as I remember for 5.x.  But I started later in the 5.x cycle.
IIRC there is a note in 5.1? or later referring to this being the required method going forward.  (meaning you would have to hit the backlight button after changing the dropdown)
Found it:
The 5.1.0 (RC2) Release is now available.
-      New – Some changes to the Admin Console
o   You now have to press the button when issuing a command for a node on the device page (rather than just change a parameter for the command to automatically be submitted)
Edited by gzahar
Don't want to hijack this thread but, has anyone else noticed that the color temp of back light of a 2334-2 6 button dimmer changed from v43 to v44. Had to rearrange a bunch to get adjacent dimmers to have the same color.  V44 looks a lot cooler than v43 and of course the brightness levels are way different.
Paul
