SWL keeps saving as Contact Sensor in Portal
Hi guys,
I have a SWL that wouldn't respond to alexa voice command (Turn on, dim, etc)
I went to the ISY Portal and noticed it was saved as a Contact sensor.
I switched it to Light and saved, closed, and backed out. I had Alexa browser app forget the device and rediscover it.
When I try a voice command same problem.
I go back to ISY Portal and find its switched back to Contact sensor.
I'm not sure what I'm doing wrong.
Drew
Upon second glance many lights are listed as contact sensor but they respond to Alexa voice command.
Edited by andrew77
5 minutes ago, andrew77 said:
Hi guys,
Drew
What is the ISY Category (The "ISY Cat." column) ?
After switching it to light and saving, does the Alexa Cat. column still shows it as Light?
Hi bmercier
Sorry for not including that.
ISY Category is Device and Alexa Category is Device/Light
I should also add Alexa says "Library doesn't support that" when I ask Alexa to dim or turn on library SWL
Edited by andrew77
29 minutes ago, andrew77 said:
Hi bmercier
To help troubleshoot this, keep an eye on that page. You can refresh using the refresh icon. No need to edit it. Technically, it should never be changed, except when editing if the values are considered invalid.
I would suggest to change the spoken and retry. Sometimes, Alexa will understand incorrectly, especially if you have other devices with similar spokens. Try with something simple like "test", "kitchen" or "living room", common names that are easily recognizable.
Hi bmercier
Adding another spoken command worked great. I called it 'book room' but was tempted to use 'Libary' a la Fonzie. haha
I'd like to know why it didn't recognize library as a command as its not an uncommon word.
Would that be something I'd give as feedback to amazon? or an Alexa forum?
Regardless, thanks again.
Drew
4 hours ago, andrew77 said:
Hi bmercier
Drew
Feedback to Amazon I guess. I never tried to report/investigate why a specific spoken would not work.
Benoti
