2441TH Insteon Thermostat resets to 50F randomly
I have 2 thermostats connected to 994 v4.7.3
If set manually on device or via UI t oany temperature (69F here), they reset to 50F automatically after few minutes. What is this! it drives me crazy
Sun 04/14/2019 19:30:54 : [  25 18 A3 1]   CLISPH 138
Sun 04/14/2019 19:33:54 : [  25 18 A3 1]   CLISPH 100
Sun 04/14/2019 19:34:26 : [  25 18 A3 1]   CLISPH 138
Sun 04/14/2019 19:38:52 : [  25 18 A3 1]   CLISPH 100
No programs. I have 3 thermostats - 2 okder models and 1 newer. Only 2 older ones do this. Maybe they were added as wrong model number. I will re-add them today.
Ok. 2 of the 2441TH are v.0D and one is v.10
v.10 works fine
2 of the v.0D reset to 50 degrees by themselves. Below is me setting it to 69F and then it resets to 50F 4:02 later.
looks as if it is coming from ISY....
Mon 04/15/2019 13:20:01 : [INST-TX-I2CS] 02 62 25 18 A3 1F 6D 8A 00 00 00 00 00 00 00 00 00 00 00 00 00 09
Mon 04/15/2019 13:20:01 : [INST-ACK    ] 02 62 25.18.A3 1F 6D 8A 00 00 00 00 00 00 00 00 00 00 00 00 00 09 06        (8A)
Mon 04/15/2019 13:20:02 : [INST-SRX    ] 02 50 25.18.A3 3D.C7.19 2F 6D 8A           (8A)
Mon 04/15/2019 13:20:02 : [Std-Direct Ack] 25.18.A3-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 04/15/2019 13:20:02 : [D2D EVENT   ] Event [25 18 A3 1] [CLISPH] [138] uom=0 prec=-1
Mon 04/15/2019 13:20:02 : [  25 18 A3 1]   CLISPH 138
Mon 04/15/2019 13:20:06 : [INST-SRX    ] 02 50 25.18.A3 3D.C7.19 05 72 45           (45)
Mon 04/15/2019 13:20:06 : [Std-Direct  ] 25.18.A3-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:20:27 : [INST-SRX    ] 02 50 25.18.54 3D.C7.19 05 6F 35           (35)
Mon 04/15/2019 13:20:27 : [Std-Direct  ] 25.18.54-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:20:27 : [D2D EVENT   ] Event [25 18 54 1] [CLIHUM] [53] uom=0 prec=-1
Mon 04/15/2019 13:20:27 : [  25 18 54 1]   CLIHUM  53
Mon 04/15/2019 13:20:46 : [INST-SRX    ] 02 50 4F.66.27 3D.C7.19 05 6F 28           (28)
Mon 04/15/2019 13:20:46 : [Std-Direct  ] 4F.66.27-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:20:46 : [D2D EVENT   ] Event [4F 66 27 1] [CLIHUM] [40] uom=0 prec=-1
Mon 04/15/2019 13:20:46 : [  4F 66 27 1]   CLIHUM  40
Mon 04/15/2019 13:21:33 : [INST-SRX    ] 02 50 25.18.54 3D.C7.19 05 6F 36           (36)
Mon 04/15/2019 13:21:33 : [Std-Direct  ] 25.18.54-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:21:33 : [D2D EVENT   ] Event [25 18 54 1] [CLIHUM] [54] uom=0 prec=-1
Mon 04/15/2019 13:21:33 : [  25 18 54 1]   CLIHUM  54
Mon 04/15/2019 13:21:47 : [INST-SRX    ] 02 50 4F.66.27 3D.C7.19 05 6F 29           (29)
Mon 04/15/2019 13:21:47 : [Std-Direct  ] 4F.66.27-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:21:47 : [D2D EVENT   ] Event [4F 66 27 1] [CLIHUM] [41] uom=0 prec=-1
Mon 04/15/2019 13:21:47 : [  4F 66 27 1]   CLIHUM  41
Mon 04/15/2019 13:21:51 : [INST-SRX    ] 02 50 25.18.54 3D.C7.19 05 6F 35           (35)
Mon 04/15/2019 13:21:51 : [Std-Direct  ] 25.18.54-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:21:51 : [D2D EVENT   ] Event [25 18 54 1] [CLIHUM] [53] uom=0 prec=-1
Mon 04/15/2019 13:21:51 : [  25 18 54 1]   CLIHUM  53
Mon 04/15/2019 13:22:22 : [ELK 1   0  0] Area : House : Not Ready To Arm (2/0/0)
Mon 04/15/2019 13:22:25 : [ELK 1   0  0] Area : House : Ready To Arm (2/1/0)
Mon 04/15/2019 13:22:44 : [INST-SRX    ] 02 50 14.C0.61 00.00.01 CF 11 01    LTONRR (01)
Mon 04/15/2019 13:22:44 : [Std-Group   ] 14.C0.61-->Group=1, Max Hops=3, Hops Left=3
Mon 04/15/2019 13:22:44 : [D2D EVENT   ] Event [14 C0 61 1] [DON] [1] uom=0 prec=-1
Mon 04/15/2019 13:22:44 : [  14 C0 61 1]      DON   1
Mon 04/15/2019 13:22:44 : [D2D-CMP 001A] CTL [14 C0 61 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Mon 04/15/2019 13:22:44 : [D2D EVENT   ] Event [14 C0 61 1] [ST] [255] uom=0 prec=-1
Mon 04/15/2019 13:22:44 : [  14 C0 61 1]       ST 255
Mon 04/15/2019 13:22:44 : [INST-DUP    ] Previous message ignored.
Mon 04/15/2019 13:22:44 : [INST-SRX    ] 02 50 14.C0.61 3D.C7.19 45 11 01    LTONRR (01)
Mon 04/15/2019 13:22:44 : [Std-Cleanup ] 14.C0.61-->ISY/PLM Group=1, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:22:44 : [INST-SRX    ] 02 50 14.C0.61 11.01.01 CF 06 00           (00)
Mon 04/15/2019 13:22:44 : [Std-Group   ] 14.C0.61-->11.01.01, Max Hops=3, Hops Left=3
Mon 04/15/2019 13:22:44 : [INST-INFO   ] Previous message ignored.
Mon 04/15/2019 13:22:45 : [INST-SRX    ] 02 50 14.C0.61 11.01.01 CF 06 00           (00)
Mon 04/15/2019 13:22:45 : [Std-Group   ] 14.C0.61-->11.01.01, Max Hops=3, Hops Left=3
Mon 04/15/2019 13:22:45 : [INST-INFO   ] Previous message ignored.
Mon 04/15/2019 13:22:48 : [INST-SRX    ] 02 50 4F.66.27 3D.C7.19 05 6F 28           (28)
Mon 04/15/2019 13:22:48 : [Std-Direct  ] 4F.66.27-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:22:48 : [D2D EVENT   ] Event [4F 66 27 1] [CLIHUM] [40] uom=0 prec=-1
Mon 04/15/2019 13:22:48 : [  4F 66 27 1]   CLIHUM  40
Mon 04/15/2019 13:23:04 : [ELK 1   0  0] Area : House : Not Ready To Arm (2/0/0)
Mon 04/15/2019 13:23:08 : [INST-SRX    ] 02 50 25.18.54 3D.C7.19 05 6F 36           (36)
Mon 04/15/2019 13:23:08 : [Std-Direct  ] 25.18.54-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:23:08 : [D2D EVENT   ] Event [25 18 54 1] [CLIHUM] [54] uom=0 prec=-1
Mon 04/15/2019 13:23:08 : [  25 18 54 1]   CLIHUM  54
Mon 04/15/2019 13:23:14 : [INST-SRX    ] 02 50 25.18.54 3D.C7.19 05 6F 35           (35)
Mon 04/15/2019 13:23:14 : [Std-Direct  ] 25.18.54-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:23:14 : [D2D EVENT   ] Event [25 18 54 1] [CLIHUM] [53] uom=0 prec=-1
Mon 04/15/2019 13:23:14 : [  25 18 54 1]   CLIHUM  53
Mon 04/15/2019 13:23:19 : [INST-SRX    ] 02 50 14.C0.61 00.00.01 CF 13 01    LTOFFRR(01)
Mon 04/15/2019 13:23:19 : [Std-Group   ] 14.C0.61-->Group=1, Max Hops=3, Hops Left=3
Mon 04/15/2019 13:23:19 : [D2D EVENT   ] Event [14 C0 61 1] [DOF] [1] uom=0 prec=-1
Mon 04/15/2019 13:23:19 : [  14 C0 61 1]      DOF   1
Mon 04/15/2019 13:23:19 : [D2D EVENT   ] Event [14 C0 61 1] [ST] [0] uom=0 prec=-1
Mon 04/15/2019 13:23:19 : [  14 C0 61 1]       ST   0
Mon 04/15/2019 13:23:19 : [ELK 1   0  0] Area : House : Ready To Arm (2/1/0)
Mon 04/15/2019 13:23:19 : [INST-DUP    ] Previous message ignored.
Mon 04/15/2019 13:23:19 : [INST-SRX    ] 02 50 14.C0.61 3D.C7.19 45 13 01    LTOFFRR(01)
Mon 04/15/2019 13:23:19 : [Std-Cleanup ] 14.C0.61-->ISY/PLM Group=1, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:23:19 : [INST-SRX    ] 02 50 14.C0.61 13.01.01 CF 06 00           (00)
Mon 04/15/2019 13:23:19 : [Std-Group   ] 14.C0.61-->13.01.01, Max Hops=3, Hops Left=3
Mon 04/15/2019 13:23:19 : [INST-INFO   ] Previous message ignored.
Mon 04/15/2019 13:23:38 : [INST-SRX    ] 02 50 25.18.54 3D.C7.19 05 6F 36           (36)
Mon 04/15/2019 13:23:38 : [Std-Direct  ] 25.18.54-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:23:38 : [D2D EVENT   ] Event [25 18 54 1] [CLIHUM] [54] uom=0 prec=-1
Mon 04/15/2019 13:23:38 : [  25 18 54 1]   CLIHUM  54
Mon 04/15/2019 13:23:39 : [ELK 1   0  0] Area : House : Not Ready To Arm (2/0/0)
Mon 04/15/2019 13:23:43 : [ELK 1   0  0] Area : House : Ready To Arm (2/1/0)
Mon 04/15/2019 13:23:49 : [INST-SRX    ] 02 50 4F.66.27 3D.C7.19 05 6F 2A           (2A)
Mon 04/15/2019 13:23:49 : [Std-Direct  ] 4F.66.27-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:23:49 : [D2D EVENT   ] Event [4F 66 27 1] [CLIHUM] [42] uom=0 prec=-1
Mon 04/15/2019 13:23:49 : [  4F 66 27 1]   CLIHUM  42
Mon 04/15/2019 13:24:04 : [INST-TX-I2CS] 02 62 25 18 A3 1F 6D 64 00 00 00 00 00 00 00 00 00 00 00 00 00 2F
Mon 04/15/2019 13:24:04 : [INST-ACK    ] 02 62 25.18.A3 1F 6D 64 00 00 00 00 00 00 00 00 00 00 00 00 00 2F 06        (64)
Mon 04/15/2019 13:24:04 : [INST-SRX    ] 02 50 25.18.A3 3D.C7.19 2F 6D 64           (64)
Mon 04/15/2019 13:24:04 : [Std-Direct Ack] 25.18.A3-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 04/15/2019 13:24:04 : [D2D EVENT   ] Event [25 18 A3 1] [CLISPH] [100] uom=0 prec=-1
Mon 04/15/2019 13:24:04 : [  25 18 A3 1]   CLISPH 100
Mon 04/15/2019 13:24:05 : [INST-TX-I2CS] 02 62 25 18 54 1F 6D 64 00 00 00 00 00 00 00 00 00 00 00 00 00 2F
Mon 04/15/2019 13:24:06 : [INST-ACK    ] 02 62 25.18.54 1F 6D 64 00 00 00 00 00 00 00 00 00 00 00 00 00 2F 06        (64)
Mon 04/15/2019 13:24:06 : [INST-SRX    ] 02 50 25.18.54 3D.C7.19 2F 6D 64           (64)
Mon 04/15/2019 13:24:06 : [Std-Direct Ack] 25.18.54-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Mon 04/15/2019 13:24:08 : [INST-SRX    ] 02 50 25.18.A3 3D.C7.19 05 72 32           (32)
Mon 04/15/2019 13:24:08 : [Std-Direct  ] 25.18.A3-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:24:16 : [INST-SRX    ] 02 50 25.18.54 3D.C7.19 05 6F 35           (35)
Mon 04/15/2019 13:24:16 : [Std-Direct  ] 25.18.54-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:24:16 : [D2D EVENT   ] Event [25 18 54 1] [CLIHUM] [53] uom=0 prec=-1
Mon 04/15/2019 13:24:16 : [  25 18 54 1]   CLIHUM  53
Mon 04/15/2019 13:24:20 : [ELK 1   0  0] Area : House : Not Ready To Arm (2/0/0)
Mon 04/15/2019 13:24:23 : [ELK 1   0  0] Area : House : Ready To Arm (2/1/0)
Mon 04/15/2019 13:24:28 : [ELK 1   0  0] Area : House : Not Ready To Arm (2/0/0)
Mon 04/15/2019 13:24:30 : [ELK 1   0  0] Area : House : Ready To Arm (2/1/0)
Mon 04/15/2019 13:25:12 : [INST-SRX    ] 02 50 25.18.54 3D.C7.19 05 6F 34           (34)
Mon 04/15/2019 13:25:12 : [Std-Direct  ] 25.18.54-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Mon 04/15/2019 13:25:12 : [D2D EVENT   ] Event [25 18 54 1] [CLIHUM] [52] uom=0 prec=-1
Mon 04/15/2019 13:25:12 : [  25 18 54 1]   CLIHUM  52
