I dont get it...
all, my ISY/insteon setup has been running perfectly for 5+ years.
today, I have an issue and I just can't put my finger on the problem.
setup: one insteon 2450 for the garage door and 2 keypad with a "garage door" button. they have been working great for years. allows to control the garage door and get the status of it
today. one of the 2 keypad button cannot control the garage door, but it can gets the status of it and when I press the button, the second keypad button lights up.
the other button works just great.
so communication seems fine... or not?
I power cycled everything, deleted and re-created the scene. same thing... upgrade the ISY to 4.7.3 (yes I had hopes for magic)
only thing I can think of, the insteon 2450 life is about to expire after 5+ years in a cold/hot and humid garage.
here are some logs when I press the "defective" button. anyone can understand those?
insteon 2450 is 34-88-62
"defective" button: 34-dd-55 (bouton E)
Sat 04/20/2019 09:20:13 PM : [INST-SRX    ] 02 50 34.DD.55 00.00.05 CF 11 00    LTONRR (00)
Sat 04/20/2019 09:20:13 PM : [Std-Group   ] 34.DD.55-->Group=5, Max Hops=3, Hops Left=3
Sat 04/20/2019 09:20:13 PM : [D2D EVENT   ] Event [34 DD 55 5] [DON] [0] uom=0 prec=-1
Sat 04/20/2019 09:20:13 PM : [  34 DD 55 5]      DON   0
Sat 04/20/2019 09:20:14 PM : [INST-SRX    ] 02 50 34.DD.55 40.55.2D 40 11 05    LTONRR (05)
Sat 04/20/2019 09:20:14 PM : [Std-Cleanup ] 34.DD.55-->ISY/PLM Group=5, Max Hops=0, Hops Left=0
Sat 04/20/2019 09:20:14 PM : [INST-DUP    ] Previous message ignored.
Sat 04/20/2019 09:20:15 PM : [INST-SRX    ] 02 50 34.DD.55 11.03.05 CF 06 01           (01)
Sat 04/20/2019 09:20:15 PM : [Std-Group   ] 34.DD.55-->11.03.05, Max Hops=3, Hops Left=3
Sat 04/20/2019 09:20:15 PM : [INST-INFO   ] Previous message ignored.
Sat 04/20/2019 09:20:42 PM : [INST-SRX    ] 02 50 32.9F.7A 00.00.01 CB 11 01    LTONRR (01)
Sat 04/20/2019 09:20:42 PM : [Std-Group   ] 32.9F.7A-->Group=1, Max Hops=3, Hops Left=2
Sat 04/20/2019 09:20:42 PM : [D2D EVENT   ] Event [32 9F 7A 1] [DON] [1] uom=0 prec=-1
Sat 04/20/2019 09:20:42 PM : [  32 9F 7A 1]      DON   1
Sat 04/20/2019 09:20:42 PM : [D2D EVENT   ] Event [32 9F 7A 1] [ST] [255] uom=0 prec=-1
Sat 04/20/2019 09:20:42 PM : [  32 9F 7A 1]       ST 255
Sat 04/20/2019 09:20:42 PM : [D2D-CMP 0048] STS [32 9F 7A 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Sat 04/20/2019 09:20:42 PM : [D2D-CMP 0041] STS [32 9F 7A 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Sat 04/20/2019 09:20:42 PM : [D2D-CMP 004D] STS [32 9F 7A 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true
Sat 04/20/2019 09:20:42 PM : [INST-SRX    ] 02 50 32.9F.7A 40.55.2D 41 11 01    LTONRR (01)
Sat 04/20/2019 09:20:42 PM : [Std-Cleanup ] 32.9F.7A-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Sat 04/20/2019 09:20:42 PM : [INST-DUP    ] Previous message ignored.
Sat 04/20/2019 09:20:42 PM : [INST-SRX    ] 02 50 32.9F.7A 11.01.01 CB 06 00           (00)
Sat 04/20/2019 09:20:42 PM : [Std-Group   ] 32.9F.7A-->11.01.01, Max Hops=3, Hops Left=2
Sat 04/20/2019 09:20:42 PM : [INST-INFO   ] Previous message ignored.
Sat 04/20/2019 09:20:43 PM : [INST-SRX    ] 02 50 32.9F.7A 11.01.01 CB 06 00           (00)
Sat 04/20/2019 09:20:43 PM : [Std-Group   ] 32.9F.7A-->11.01.01, Max Hops=3, Hops Left=2
Sat 04/20/2019 09:20:43 PM : [INST-INFO   ] Previous message ignored.
Sat 04/20/2019 09:21:07 PM : [INST-SRX    ] 02 50 32.9F.7A 00.00.01 CB 13 01    LTOFFRR(01)
Sat 04/20/2019 09:21:07 PM : [Std-Group   ] 32.9F.7A-->Group=1, Max Hops=3, Hops Left=2
Sat 04/20/2019 09:21:07 PM : [D2D EVENT   ] Event [32 9F 7A 1] [DOF] [1] uom=0 prec=-1
Sat 04/20/2019 09:21:07 PM : [  32 9F 7A 1]      DOF   1
Sat 04/20/2019 09:21:07 PM : [D2D EVENT   ] Event [32 9F 7A 1] [ST] [0] uom=0 prec=-1
Sat 04/20/2019 09:21:07 PM : [  32 9F 7A 1]       ST   0
Sat 04/20/2019 09:21:07 PM : [D2D-CMP 0048] STS [32 9F 7A 1] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Sat 04/20/2019 09:21:07 PM : [D2D-CMP 0041] STS [32 9F 7A 1] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Sat 04/20/2019 09:21:07 PM : [D2D-CMP 004D] STS [32 9F 7A 1] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Sat 04/20/2019 09:21:08 PM : [INST-SRX    ] 02 50 32.9F.7A 40.55.2D 41 13 01    LTOFFRR(01)
Sat 04/20/2019 09:21:08 PM : [Std-Cleanup ] 32.9F.7A-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Sat 04/20/2019 09:21:08 PM : [INST-DUP    ] Previous message ignored.
Sat 04/20/2019 09:21:08 PM : [INST-SRX    ] 02 50 32.9F.7A 13.01.01 CB 06 00           (00)
Sat 04/20/2019 09:21:08 PM : [Std-Group   ] 32.9F.7A-->13.01.01, Max Hops=3, Hops Left=2
Sat 04/20/2019 09:21:08 PM : [INST-INFO   ] Previous message ignored.
ok, found it... it's always when you search for over an hour and finaly decide to reach out that you find the answer...
bought a used laptop, connected in the garage. unplug it and.. voila!
anyone can point which (if any) of the lines of logs points to the communication issue?
thansk
The problem is that the log shows communication between the ISY/PLM and devices not communication between devices.  You had a communication problem between a keypad and the 2450 which isn't captured by the log.
Still, every line in the log that refers to device 32.9F.7A shows a "Hops Left" that is less than "Max Hops".  This could be an indication of a communication problem.
