Response type 10 (on upgrade to v5)
Needed to change some hardware, came with v5.0.13D. After advice here and from support, elected to restore from v4.6.3 backups.
Seemed to go OK, from what I can see so far, but four programs have an "unsaved" state (I did already force a save once, actually twice, and restarted), they are listed below.
They also curiously have a "Response type 10", have no idea what that means, probably part of the issue.
* Orest
_____________________________________________________________________________
queryAll - [ID 0002][Parent 0001]
        Time is  2:45:00AM
        Response type 10
query tstats - [ID 010C][Parent 0001]
        Time is 12:00:00AM
    And Time is  6:00:00AM
    And Time is 12:00:00PM
    And Time is  6:00:00PM
        Response type 10
        Response type 10
        Response type 10
        Response type 10
tstat high.sense - [ID 01CB][Parent 0074]
             'thermostats / MAIN - tstat - 2.2 -' Temperature > 27.0°
          Or 'thermostats / Master - tstat - 2.2 -' Temperature > 27.0°
          Or 'thermostats / UpStrs - tstat - 2.2 -' Temperature > 27.0°
          Or 'thermostats / SLRM - tstat - 2.2 -' Temperature > 29.0°
    And Program 'var tstat high' is False
        Wait  1 minute
        Response type 10
        Response type 10
        Response type 10
        Response type 10
        Wait  1 minute
        Run Program 'tstat high' (If)
tstat low.sense - [ID 01CC][Parent 0074]
             'thermostats / MAIN - tstat - 2.2 -' Temperature < 15.0°
          Or 'thermostats / Master - tstat - 2.2 -' Temperature < 15.0°
          Or 'thermostats / UpStrs - tstat - 2.2 -' Temperature < 15.0°
          Or 'thermostats / SLRM - tstat - 2.2 -' Temperature < 15.0°
    And Program 'var tstat low' is False
        Wait  1 minute
        Response type 10
        Response type 10
        Response type 10
        Response type 10
        Wait  1 minute
        Run Program 'tstat low' (If)
It appears this is a placeholder for statements it can't translate. These are a SCENE query and a THERMOSTAT query.
OK, fixed those.
Scanned through 8000 lines of code ...
Looks like it was mainly adding [Not Enabled] to a few dozen functions, which stopped the weird house behavior, not surprising!
The backup/restore did go pretty smoothly. But moving to v5 is not a trivial exercise, if your application is well developed. But, I suppose you have to do it sometime, and now I can start checking out all the new features.
Is there a good top level summary of these, somewhere?
* Orest
Edited by oskrypuch
