Lamplinc 2457D2 Status LED Dimming
Just installed 4 Lamplinc Dimmers in a Master Bedroom.  They are plugged into a single power bar.  The light emitting from the status LEDs is bothering my sleep.  How do I dim the status LED on a Lamplinc using ISY?  The  On/Off modules have tabs to accomplish this but not the Lamplincs.
PhanTomiZ
Thanks for the prompt response, but I was hoping I missed something and was able to do it through the ISY as I do with the On/Off modules.
The manual does not show a software only option. For the LED brightness. Possible it can not be done through the ISY994i controller.
In the full users manual. In the Local Programming Flow Chart. There is a sequence to adjust the LED brightness. You may want to try it and see if it could possibly be of some help.
I have used the Light Dims product to dim my bright Blue LED on the ISY994i. It is a set of stickers of assorted size and shapes. You can stick over things like LEDs. I believe mine where the 80% blocking ones. They do have a 100% blockage one also.
http://www.lightdims.com/index.php
Edited by Brian H
Add Information.
