Another question.
Here is my Home Folder.
Folder Conditions for 'HOME'
Add conditions to limit when programs in this folder are allowed to run.
Status 'GAR KPL H' is On
And Status 'MBR KPL H' is On
And Status 'Occupied On/OFF APL' is On
And here is my Clock On trigger.
From Sunset
To 10:35:00PM (same day)
And Status 'Garage Clock APL' is Off
Set 'Garage Clock APL' On
If I get home after sunset and I set ISY that I'm HOME, I'd think that the clock would come on as I'm between Sunset and 10:35. It doesn't even I querry.
What am I doing wrong here?
aLf
Hi,
As for what I know, programs are not evaluated unless you call them explicitly by their IF part or at the very moment a trigger happens.
The schedule "From Sunset to 10:35PM" has 2 triggers : Sunset and 10:35. If the program becomes "accessible" between these 2 triggers, it will be available for running, but will not start on its own before its own triggers.
A fix would be to have a program like :
If "Control Occupied On/Off APL" is switched On
Run program "Clock trigger" ( IF )
With that, every time you turn your "Occupied" flag On, the clock is re-evaluated. If it is true, its Then part will run. If it is not, nothing will happen because you have no Else part.
Jacques
Hi,
Jacques
So as an example would aLf want his Home Folder condition to be:
Or
Control 'GAR KPL H' is Switched On
Or Control 'MBR KPL H' is Switched On
Or Control 'Occupied On/OFF APL' is Switched On
That way if the status part of the program is true when the Clock schedule trigger occurs the clock program will run. And if the statement wasnt true when the schedule trigger occured but one of the KPL's were switched on during the clock schedule time period, then the program would run.
Is this correct?
Hi TJF,
I would suggest using the Status in the folder Conditioons to activate/deactivate and the Control checks to trigger the programs.
Folders can also be nested so a Status check could be inside a Scheduled folder, etc.
Rand
