EZRain EZFlora valve address missing
I have an EZRain device and while it works properly I can't see the address for the individual vales anywhere.  I could have sworn I used to see them.  At some point long ago I added the EZ Rain and renamed the valves to their function. In the device table it has the address as 05.92.EE  Where can I recover the individual valve number?
All zones have the same insteon ID address, plus a zone number. If you pick a valve in the admin console, and look at the very top of the admin console, under the device name is the address. Its been a while since I used an EZ, but I think there should be a single digit number after the insteon address xx:xx:xx #
That should be it.
Paul
On 7/12/2019 at 12:34 PM, dbencivengo said:
I understand the address scheme and the zone digit is just not displayed.  The six digit Insteon address is displayed and that's it.
Tools -> Generate Topology will create an html file that you can download and view. There, it will show you the Insteon address with the suffix (1-8) indicating the channel number along with the current channel name.
