That time again... Mobilinc HD, router change, can't reconnect
Hi all -
Well, once or twice a year I lose connectivity between Mobilinc HD and my ISY for one reason or another.
Where can I find the most recent Mobilinc HD instructions? The instructions I found on the Mobilinc site seem to only be for Mobilinc X now.
Any help appreciated!
Edited by Andrew
Hi @Andrew
If you are using MobiLinc Connect and the ISY drops off due to a router change, all you need to do is reboot your ISY.
If the ISY had a fixed IP, you may need to reset the ISY's network settings first back to DHCP to get the ISY back on your new router's network.
Wes
1 hour ago, InsteonNut said:
Hi @Andrew
Wes
Thanks Wes -
I'm using Mobilinc HD - would it be the same?
[edit] Tried restarting the ISY - still works fine from my laptop, no connectivity thru Mobilinc though.
[edit 2] Ok, a little progress - I can now get to my ISY locally - however, I cannot reach it remotely (I keep getting the "Mobilinc Disconnected" error)
Edited by Andrew
