new router cannot connect with mobilinc pro
So my 9 yr old  PC is starting to fail.  I decided to replace my router as well as the PC.  Still need to set up port forwarding on the router.  In mobilinc pro, settings, lighting controller which IP is the local http://, and what IP is the https:.  what IP is the one that I will set up port forwarding in my new router?
Al
You are putting in the IP address of your ISY.  Unless you want to get to from outside of your home, then you would use your Dynamic DNS name, external static ip, or external IP address. On your router you would want that to come in on say port 8081 and forward that to the IP of your ISY port 80
Edited by bdw72
Thanks, I think I have that.  The external is one that "what's my IP" returns.
