Possible To Trigger on Program Status Change?
Right now it is possible to use a program's status as a condition in another program. eg.
       Program 'Test Program' is True
What I'd like to be able to do is trigger when a program's status changes, ie when it becomes true or false. What I have is a program that tracks the status of an X10 device and I'd like to trigger only when that device's status changes. As it stands now, if I trigger on program status, potentially I will retrigger over and over until the status changes again. My work around is simple: trigger on X10 received but I think that linking to a tracked status would be more elegant. :D
-David
I do something like this using a second, empty program that tracks the previous status, using logic like:
 And Program 'Test Program Old Status' is False
     Run Program 'Test Program Old Status' (Then Path)
     ## and do what you want to do on change here
 - No Actions
I have an equivalent program to check if "Test Program" is False and "Test Program Old Status" is True, which runs the Else case on old status. This allows me to detect when the status changes, make note of that detail, and then do something.
