ZLINK ZL-PD-100 Plug-in Dimmer Module Overview
Hi, recently hooked this up and it works great.
http://www.zlinkproducts.com/products/zlink-products-plug-in-dimmer-module-zl-pd-100
I bought as a dimmer for a lamp in our master bedroom. It was cheapest dimmer I could find.
Setting up is very easy... one button tap to include/exclude.
Only has one node when included in ISY network... nothing special so not worth a screen shot.
I setup in a scene as a responder with Insteon KeypadLInc button and works like one would expect. Typical options like other Z-Wave dimmers for using default brightness (or last brightness), or a Command that sets specific brightness from a scene.
The physical device has a bright nightlight on it but fortunately it can be disabled using a Z-Wave parameter or even operation inverted depending it it is on or off.
Edited by brians
typo
