New imac, old admin console version
I updated to a new imac with Mojave, and moved everything over without much of an issue. I believe the Admin Console was working after the move. I haven't had a need to use the console in many months, and the isy994i still had 4.3.26 on it. I now have java version 8 update 231 on it, and now problems have arisen. I noticed one of my programs wasn't working as it should, so i made a minor change yesterday with no problem. I tried again this morning to open the console, and it won't , so i downloaded the admin.jnlp and managed to get the console to slowly open to the login. After attempting to login, the fields populate devices, with some missing, and i get a jre error. i ty to update the isy to 4.7.3 as per the notice at the top of the console to no avail. Tried to manually update, and it times out. Sometimes i can login, sometimes the isy is not found. I disabled Avast, but that didn't solve the problem. I tried again and i get 3 errors, and the login page doesn't show up.
I need help. I assume it's the old version on the isy, and a new java problem. I can access everything fine from mobilinc on my phone or ipad.
Brad
I downloaded the isy launcher from the link, and upgraded the isy to 4.7.3. Now the console won't load again. I tried clearing java cache, and using the link to download the launcher, but it does not find the isy.
I followed the link from above, cleared the java cache, and when i hit the link for the isy launcher, it says to select the version of isy from the menu, but there is no choice, it just downloads a version of isy launcher which doesn't work after the upgrade. Below is a screenshot after clicking on the link
When you cleared your java cache did you check all 3 boxes.  If so it will delete the ISY launcher from your desktop and require you to download it again.
The ISY version in the launcher window should then match your ISY firmware version.
I didn't do that before, but i tried again with all 3 boxes checked, and downloaded the start .jlp from the link. There was still no choice or drop down menu. The first time i tried, i got as far as the login page, after a slow start, and then i get an error. I tried the whole process again, and i don't get to the login window before i get an error message. I tried a 3rd time and it didn't even find the isy that time. Frustrating after years with very little connection problems.
Edited by bmiller
