Turn Lights On When Garage Door Opens
I have a program alerts me when my garage door goes up or down with a text.  See attached screenshot.  I want to add to the Then clause to turn on the scene for garage ceiling lights.  I just replaced the old conventional 3-way switches with INSTEON 2477S switches.  I have a scene in called Garage Ceiling Lights and both switches are controllers in the scene.  Manually, the scene works fine. I can turn the lights on or off from either switch.   I tried adding the commands to turn on this scene at the end of the Then clause, added a Wait 2 minutes followed by a turn the scene off command.  When I tested it by opening the garage door, the lights came on momentarily but then turned off.  When I looked at the program status, it was not in a wait state.  So I clearly don't have this right.  How can I implement this desired functionality? Thanks!
So I just tried only adding the command: Set 'Garage Ceiling Lights' On to the Then clause and it works fine.  The lights come on and stay on.  Do I have to switch them off after 5 minutes in a separate program?
Well I feel pretty silly.  I thought I was setting the wait for 2 minutes and I really set it for 2 seconds! Duh!  The Wait for 2 minutes and then turn the scene off works fine.  My apologies for dumb questions.
