REST Control of COLOR_SWITCH
I have a HSM200 that I just set up. This is a Zwave RGB light with various sensors (Motion, lux, temp). Lux and Temp report OK, but I'm looking for some guidance on how to control the light.
In Admin Console, I have a device ZW005_186 which is the COLOR_SWITCH control. It shows three values, R, G and B. For some reason there are three buttons, "fade up", "fade down" and "fade stop", for each of which I can pick a channel (red, green, blue). Clicking on these increases the red/green/blue channel up or down 1 value (and the light responds). So it works, but you can't really set a colour this way.
There are three properties reported, GV2, GV3, and GV4 which correspond like this:
ZW 005 Color Switch/GV4 0   #blue
ZW 005 Color Switch/GV3 0   #green
ZW 005 Color Switch/GV2 0   #red
This is the output of `/rest/zwave/node/ZW005_186/def/get`
<nodeDefs>
<nodedef id="UZW00F4" nls="186">
<sts>
<st id="GV2" editor="_107_0_R_0_255"/>
<st id="GV3" editor="_107_0_R_0_255"/>
<st id="GV4" editor="_107_0_R_0_255"/>
</sts>
<cmds>
<sends/>
<accepts>
<cmd id="DON">
<p id="GV2" editor="_107_0_R_0_255" optional="T"/>
<p id="GV3" editor="_107_0_R_0_255" optional="T"/>
<p id="GV4" editor="_107_0_R_0_255" optional="T"/>
</cmd>
<cmd id="FDUP">
<p id="ID" editor="_25_0_S_001C_N_IX_CCI"/>
<p id="STARTLEVEL" editor="_107_0_R_0_255" optional="T"/>
</cmd>
<cmd id="FDDOWN">
</cmd>
<cmd id="FDSTOP">
</cmd>
<cmd id="QUERY"/>
</accepts>
</cmds>
<links>
<ctl/>
<rsp>
<link linkdef="ASSOC_MC"/>
<link linkdef="ASSOC_CMD"/>
<link linkdef="ASSOC"/>
</rsp>
</links>
</nodedef>
</nodeDefs>
and the output of `/rest/nodes/ZW005_186`
<nodeInfo>
<node flag="0" nodeDefId="UZW00F4">
<address>ZW005_186</address>
<name>ZW 005 Color Switch</name>
<family>4</family>
<parent type="1">ZW005_1</parent>
<type>4.7.1.0</type>
<enabled>true</enabled>
<deviceClass>0</deviceClass>
<wattage>0</wattage>
<dcPeriod>0</dcPeriod>
<startDelay>0</startDelay>
<endDelay>0</endDelay>
<pnode>ZW005_1</pnode>
<sgid>186</sgid>
<devtype>
<gen>4.7.1</gen>
<mfg>30.4.1</mfg>
<cat>186</cat>
</devtype>
<ELK_ID>P03</ELK_ID>
</node>
<properties>
<property id="GV2" value="6" formatted="6" uom="107"/>
<property id="GV3" value="0" formatted="0" uom="107"/>
<property id="GV4" value="0" formatted="0" uom="107"/>
</properties>
</nodeInfo>
I would like to set the RGB value using the REST interface, but so far I can't find any combination of commands that changes anything for this node.
Can anyone shed some light on how to set GV2,3,4 via REST?
UPDATE:
Had a brainwave after posting this, and finally figured it out.
The REST command is `/rest/nodes/ZW005_186/cmd/DON?GV2=0&GV3=255&GV4=0` which sets r=0, g=255, b=0 (ie green) or any other rgb combinations. And it works!
Hope this helps someone else out.
Edited by Niick_W
  • 5 months later...
This is really cool. I'm thinking about picking up a couple of these. Did it work out of the box or did you have to set any config parameters to get the sensors working / reporting correctly?
I don't believe I had to do anything. This is a bit of an oddball device though. You can only set 7 colours (ie you can't set any RGB combination, only 7 are allowed). The device has a light sensor, but also emits light - so the sensor picks up it's own light output - weird!
