March 12, 20206 yr My new ISY controller came with OS 5. I need it to control Z-wave, an option the existing controller cannot handle. After performing a "factory reset" and adding a few devices, I created a single one-line program to see if I could avoid the OUT OF MEMORY errors on all programs loaded by recovering the current OS4 backup. No luck. Even that single program fails to run and has OUT OF MEMORY emblazened in yellow. What am I doing wrong here? Edited March 12, 20206 yr by MarcV Add result of test.
March 12, 20206 yr 7 minutes ago, MarcV said: My new ISY controller came with OS 5. I need it to control Z-wave, an option the existing controller cannot handle. After performing a "factory reset" and adding a few devices, I created a single one-line program to see if I could avoid the OUT OF MEMORY errors on all programs loaded by recovering the current OS4 backup. No luck. Even that single program fails to run and has OUT OF MEMORY emblazened in yellow. What am I doing wrong here? Show me a sample of what you have installed in your system along with examples of programs. Go to any program and right mouse click and select copy to clip board and post the same here. You can show what you have installed by using the Windows Snipping tool and load that image capture.
March 12, 20206 yr Author 48 minutes ago, Teken said: Show me a sample of what you have installed in your system along with examples of programs. Go to any program and right mouse click and select copy to clip board and post the same here. You can show what you have installed by using the Windows Snipping tool and load that image capture. Summary tab shows this program OUT OF MEMORY. It is the only program. The scene Office Overhead Lights turns on/off from the scene description page tabs. Incidentally, when first selecting the Program tab, a diagnostic appears saying: NOT IMPLEMENTED. Subsequent access to Program does not exhibit that notice. TESTING - [ID 0002][Parent 0001] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set Scene 'Office Overhead Lights' On Else - No Actions - (To add one, press 'Action') Edited March 12, 20206 yr by MarcV
March 12, 20206 yr Is the old one a PRO model and the new one is not a PRO model and you maybe hitting the limitations of a non PRO model?
March 12, 20206 yr Author The new one is a PRO model. ISY994i ZW+ s/n 39.0021b902542d Edited March 12, 20206 yr by MarcV
March 12, 20206 yr Summary tab shows this program OUT OF MEMORY. It is the only program. The scene Office Overhead Lights turns on/off from the scene description page tabs. Incidentally, when first selecting the Program tab, a diagnostic appears saying: NOT IMPLEMENTED. Subsequent access to Program does not exhibit that notice. TESTING - [iD 0002][Parent 0001] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set Scene 'Office Overhead Lights' On Else - No Actions - (To add one, press 'Action') Well, you don’t have anything in the (IF) statement how does the system know what to do - based on what??? [emoji848]Sent from my iPhone using Tapatalk
March 12, 20206 yr Author Used RUN THEN, but of course nothing happens. The SUMMARY program tab says NOT LOADED and OUT OF MEMORY so I didn't really expect it to happen. Recall that this is after reseting the ISY. Originally I simply recovered an old backup, corrected some NULL commands to ON and waIted for normal timed programs to activate. None ever did. That's when I began to look around and found the OUT OF MEMORY labels. Never saw those before. I spent quite a bit of time searching here on the forums and resetting, reloading, etc., before admitting I'm at a loss to (a) understand what NOT IMPLEMENTED, NOT LOADED, and OUT OF MEMORY really mean and (b) what to do to make this thing work. Nothing I found on the Wiki or here seemed to apply. It's hard to believe that I'm the first to have this problem. But who knows? Maybe others just give up in frustration and call the Lutron dealer. Edited March 12, 20206 yr by MarcV
March 12, 20206 yr Stepping back to the beginning... can you check what version of firmware you are running, and what version of UI -- they must match. One of the many symptoms when the two do not match can be out-of-memory messages in the console.
March 12, 20206 yr Author Yes. UI is 4, Firmware is 5. You may have found my problem. From where would I get any other UI? And how will I keep them separate once loaded on the MacBook?
March 12, 20206 yr 2 minutes ago, MarcV said: Yes. UI is 4, Firmware is 5. You may have found my problem. From where would I get any other UI? And how will I keep them separate once loaded on the MacBook? Use the ISY Launcher. This will automatically match UI to ISY firmware.
March 12, 20206 yr Yes. UI is 4, Firmware is 5. You may have found my problem. From where would I get any other UI? And how will I keep them separate once loaded on the MacBook? You need only go to the beta thread for the version 5.XX you’re on. Once there download the UI that matches. Keeping in mind you need to clear the Java cache if you updated the controller. Next, an out of memory is normally related to something in the program that is no longer present.In this case I called out you have nothing in the (IF) statement. So put something in there and hit save. [emoji106]Sent from my iPhone using Tapatalk
March 12, 20206 yr Author Bless you both, including apostolakisl. I should have come to you first to save lots of time! I quit using the launcher because it added an extra keypress and seemed to make no difference. Little did I realize that it's tailored for Version 5. Thank you, thank you.
March 12, 20206 yr Bless you both, including apostolakisl. I should have come to you first to save lots of time! I quit using the launcher because it added an extra keypress and seemed to make no difference. Little did I realize that it's tailored for Version 5. Thank you, thank you. Rock On . . . [emoji106][emoji481]Sent from my iPhone using Tapatalk
