March 19, 20206 yr Using HomeAssistant 0.106.6 ISY - 5.0.16B In the ISY the innovelli creates 3 devices. From what I can tell, the "set" device is turns on and off based on the manual operation of the switch. The _1 device changes state when the switch is automated. Attempted to create a program that changes the _1 to the status of "set" labeled node. The If was where the "set" device was on or not off. Then the program would turn the _1 on Else the program would turn the _1 off. This does not seem to work as I have intended. Any suggestions?
March 22, 20206 yr Author In the ISY. was able to create the programs and get the status of the manual to match the automation.
