Displaying individual variables "as devices" (sort of like virtual devices)
7 minutes ago, markv58 said:
@gzahar @hart2hart The id is not linked to the variable, it was in the beginning but the nodeserver evolved. After much thought and feedback I decided to just have a number as the id rather than a proper name, which you can choose in the admin console and rename any time you want.
Great.  Was confused by this statement on the configuration page.  (made is sound like state variables could be used)
"There are 3 kinds of virtual devices, switch, dimmer and temperature. You do not need to have a state variable for each entry."
  • 3 months later...
I read through this entire thread and saw a couple of comments on adding a "energy" type to facilitate using variables from a Brultech Gem / DB.  I installed the NS and dont see that option.  Is it  still on the roadmap ??
...Barry
...Barry
Probably, got very busy with other projects. The "energy" part would be a separate ns because of the complexity. Planning to setup Brultech when time permits.
