ketchup318 Posted September 9, 2009 Share Posted September 9, 2009 Hi I'm trying to use my harmony remote to toggle on and off a scene for watching TV... here's the script. I don't know what's going wrong, but the "Toggle Watch TV" program is stuck looping over and over again and the lights turn on and off, until I disable the script... Any thoughts? (name:Watch_TV) -------------------------------------------------- If IR 'IR_001' is Released Then Run Program 'Toggle Watch TV' (If) Else - No Actions - (To add one, press 'Action') -------------------------------------------------- (name:Toggle Watch TV) -------------------------------------------------- If Status 'TV Light' is Off Then Set Scene 'Button B -Watch TV' On Else Set Scene 'Button B -Watch TV' Off Link to comment
MikeB Posted September 9, 2009 Share Posted September 9, 2009 How about something like this instead: WATCH TV ON If IR 'IR_001' is Pressed And Status 'TV Light' is Off Then Set Scene 'Button B - Watch TV' On Else - No Actions - (To add one, press 'Action') WATCH TV OFF If IR 'IR_001' is Pressed And Status 'TV Light' is On Then Set Scene 'Button B - Watch TV' Off Else - No Actions - (To add one, press 'Action') Link to comment
Algorithm Posted September 9, 2009 Share Posted September 9, 2009 Hello ketchup, In your original programs, simply clear the Enabled checkbox for the Toggle Watch TV program, so that it only runs when called from another program. This should prevent the oscillation. However, Mike's approach will actually be a tab bit faster, since it doesn't have one program calling another program, which adds some latency. Whether the difference would be noticeable, would need to be tested. In Mike's Watch TV Off program, I would change the line: And Status 'TV Light' is On to: And Status 'TV Light' is Not Off in case the light happened to be between 99% and 1% (not On, and not Off). Link to comment
ketchup318 Posted September 10, 2009 Author Share Posted September 10, 2009 thanks for the replies coming from a programming background, it feels a bit constrained with the fixed format of the IF Loops, but it seems to work fine now. I'm using Mike's version with two if loops, one button though... press once = on hold = off I'm really starting to like the IR option and I'm really glad to have bought it. Link to comment
MikeB Posted September 10, 2009 Share Posted September 10, 2009 In Mike's Watch TV Off program, I would change the line: Good point Darrell! Usually I'm pretty good about using "Nof OFFs", but I copied from a program I was using to control a relay. Link to comment
