Jason Miller Posted May 14, 2020 Author Share Posted May 14, 2020 I also just went back and configured Weatherbit again as well. I have nothing in my logs about this. Link to comment Share on other sites More sharing options...
bpwwer Posted May 14, 2020 Share Posted May 14, 2020 7 minutes ago, Jason Miller said: I also just went back and configured Weatherbit again as well. I have nothing in my logs about this. Hi Jason, I know that this can be frustrating. It's not easy to debug issues with Polyglot cloud even for node server developers. By default, the log is only showing errors so when it's working correctly, you shouldn't see much in the log. Unfortunately, the logging control is not part of Polyglot, but something the node server manages, which means the node server has to be up and running properly before you can enable debug logging. Not very helpful if you're having issues getting things working initially. All of the weather service node server rely on having correct configuration information to work. A lot of the configuration is passed directly to the weather service so if it's not right, the weather service simply fails to send any weather data. Where I can, I log these types of issues in the log. Like I mentioned before, the local version of polyglot includes configuration help and examples, but the cloud version of polyglot ignores the help file making configuration significantly more difficult. Here's the link to the weatherbit configuration help file: https://github.com/bpaauwe/udi-weatherbit-poly/blob/master/POLYGLOT_CONFIG.md In order to provide any real help, I'll need to know the exact configuration you're using (excepting the API key, I don't want to know your key). Link to comment Share on other sites More sharing options...
Jason Miller Posted May 14, 2020 Author Share Posted May 14, 2020 Here is my config: Link to comment Share on other sites More sharing options...
dantoronto Posted May 14, 2020 Share Posted May 14, 2020 This is my configuration for WeatherBit Key - from web site Plant type - "0.23" Elevation - I have "100" for meters Forecast days - "7" Units "M" (I live in Canada!) Location lat=xx.xxx&lon='yy.yyy" is that yours? Mine works fine. Did nothing on the ISY page, it populated itself after a few minutes. Will try Climacell now. Did you see the email from Universal Devices from today? Link to comment Share on other sites More sharing options...
dantoronto Posted May 14, 2020 Share Posted May 14, 2020 I guess I would try the location format I used above. Just to help you out, I also tried ClimaCell and it worked fine. Only change is that I used "si" for Units and filled in longitude and latitude. Prefer their format. The only issues I have are as follows: DarkSky - no problems WeatherBit, get full data in ISY but in Polyglor log I get recurring error messages that says the following and yet I am getting full data in ISY: 2020-05-08 22:47:27,813 [Controller] [WARNING] Missing data for driver CLIHUM 2020-05-08 22:47:27,813 [Controller] [WARNING] Missing data for driver DEWPT 2020-05-08 22:47:27,814 [Controller] [WARNING] Missing data for driver GV2 ClimaCell - full data in ISY except does not say "True" that it is Online Strange how different all the data is for the 3 programs. Link to comment Share on other sites More sharing options...
Jason Miller Posted May 14, 2020 Author Share Posted May 14, 2020 I think the issue is my location. I was using my zip code. I put what you had and nothing, but I think that was just an example? Link to comment Share on other sites More sharing options...
dantoronto Posted May 14, 2020 Share Posted May 14, 2020 no, you have to put n your actual coordinates. See https://www.latlong.net/ Link to comment Share on other sites More sharing options...
Jason Miller Posted May 14, 2020 Author Share Posted May 14, 2020 Link to comment Share on other sites More sharing options...
Jason Miller Posted May 14, 2020 Author Share Posted May 14, 2020 I changed my location to: Link to comment Share on other sites More sharing options...
Jason Miller Posted May 14, 2020 Author Share Posted May 14, 2020 I changed location to: lat=39.502830&lon='-76.571610" Based on the website. Is that format correct? Link to comment Share on other sites More sharing options...
dantoronto Posted May 14, 2020 Share Posted May 14, 2020 Units are "I" Location should be "lat=39.4954&lon=-76.5604" " Link to comment Share on other sites More sharing options...
dantoronto Posted May 14, 2020 Share Posted May 14, 2020 sure, if that is correct. Change your units to "I" units=[units](optional) M - [DEFAULT] Metric (Celcius, m/s, mm) S - Scientific (Kelvin, m/s, mm) I - Fahrenheit (F, mph, in) Link to comment Share on other sites More sharing options...
Jason Miller Posted May 14, 2020 Author Share Posted May 14, 2020 Ah, ok, I changed it to I. Made location: lat=39.4954&lon=-76.5604 Link to comment Share on other sites More sharing options...
Jason Miller Posted May 14, 2020 Author Share Posted May 14, 2020 I got it!!! Thank you so much for your guidance! Link to comment Share on other sites More sharing options...
Jason Miller Posted May 15, 2020 Author Share Posted May 15, 2020 Just configured my other ISY 994I on polygot and did this as well. It's at the beach, so I want to use the weather to control the blinds and such. Thanks again for your guidance. Link to comment Share on other sites More sharing options...
