Problem with an Elk-ISY program
srjacob
I posted this in the program forum and accidentally posted this to the Home Alarm forum here, but got no helpful replies.  Perhaps someone here understands what is going on.  If I can't get any help here, I will open a trouble ticket.  There doesn't seem to be any good way of tracing a program
I am running the latest ISY994 firmware and the Elk-ISY module.  I can't get this program to work.  The Elk Zone "LeftGarageDoor" is a magnetic reed switch connected to my Elk M1G zones.  It  works great.  I use the Elk as (in addition to a security system), a physical input/output connection for the Insteon lighting and ISY994.  I find that the Insteon input/output modules aren't very reliable.  Most of the time it the Elk-ISY programs work, but this is a head scratcher. LftGarageDoor is an Elk output that toggles the garage door button.  It works great.  I basically want to close the garage door when I push a "night off" button on an Insteon keypad to turn off all the lights in the house. The $GarageDoorClose is a local ISY variable that is normally set to 1.   I open the garage door.   I set $GarageDoorClose to 0 when I want the "night off" program to turn all the lights off and run (IF) this little program.   The problem here is that the garage door doesn't close, but when I run the "Then" section, the door closes just fine.
I tried reversing the two IF conditions, but it still doesn't work.
If I didn't have the $GarageDoorClose variable in there, every time the garage door would open, the reed switch would trip, the Elk would send a message to the ISY, and the garage door would stop, so that part is working.  The $GarageDoorClose  is simply a flag to let the ISY know when I want to turn off or on the close test.  I tried having $GarageDoorClose both be a state variable and an integer, but neither worked.
Using M1ToGo, I can see the "LeftGarageDoor" is violated, and when I toggle the output "LftGarageDoor", the door opens and closes fine.
Anybody have a clue as to why this doesn't automatically close the garage door?
Program.
        Elk Zone 'LeftGarageDoor' is Violated
    And $GarageDoorClose is 0
        Set Elk Output 'LftGarageDoor' On for 5 Seconds
      37.3k
      373.4k
