Configuration Device
Hi All
I bought Zwave device from Fibaro called Smart Implant link: https://www.fibaro.com/en/products/smart-implant/
I'm using the device as Connection with 3-wire 0-10V sensor using input 1 and 2 for two analog devices.
When I try to changed the value parameters as describe on the manual I get popup white message written error .
The device show results in volt but the results are much hugher than the sensor attached should show.
Someone can help me ?
Attache screenshots and manual
Zour
1.bmp 2.bmp FGBS-222-EN.pdf
  • 3 months later...
my experince is you have to set the parameters in the primary node. That would be the first one in your list of nodes this unit created.  ZW 010 Notify Sensor
